2014-09-21, 23:18
2014-09-23, 09:05
+1
But since MP2 is still not stable version I wouldn't expect this before Helix is out.
2014-09-24, 16:12
The version of TVE3.5 included in MP2 is a long way from being the finished article. In fact ultimately TVE3.5 will be a standalone product which happens to be supported by MP2 along with other "Front Ends".
I know Team MP are busily working on the TV3.5 project but at present there is no ETA. While I way be wrong I wouldn't think Margo will look at this until the first official release version is out.
2014-09-28, 11:41
Hi.
I'm a Member of Team MediaPortal and I'm doing lots of testing on MP2. As I need to use XBMC/Kodi on some devices without Windows running on, I'm very interested in having a TVE 3.5 XBMC-Plugin. As the development of this may take a while I think it's time to start this now. TVE 3.5 already is usable on a daily base with lots of TV sources like DVB-T DVB-S, IPTV,... but some sources (specially some US used ones I don't know anything about) are still under development. Overall for DVB-S already it is a successor over the old TV Server. But I still use the old one, only to have LiveTV in XBMC on my Android- Tablet...
So if someone wants to start developing I'm happy to help with testing and or making contacts to our (really busy) developers...
Thanks for reading, Claus
2015-09-08, 00:12
I'm looking at moving over the MCE to Kodi and using Mediaportal TV Server, I've had MP1 setup and working fine with Kodi on an Amazon Fire TV & my tablet, but I've been playing with MP2 but it doesn't seem to like the TVServerKodi plugin, I've tried installing the add on with MPEI and manually creating a plugins folder and copying the TVServerKodi.dll into that folder but on both occasion's it just caused MP2 TV server to crash and I had to repair the installation/reinstall.
Please note that this is using TVE3, which as I understand it is the TV engine from MP1, in fact the TV Server configuration screen actually shows it as V 1.12.0.0 so I was hoping it would work, but alas not.
Any suggestions, or is there a new version in the works for MP2?
2015-09-08, 05:56
I'm trying the same. Don't know how to add the plugin.
2015-09-08, 08:16
I wasn't too sure either, I tried the Media Portal Extension Manager, after downloading the extension from here I then used the file - open option This did something as the TV server configurator wouldn't load after this, instead crashing out with a load of errors. Just to confuse matters I have MP1 installed with the service stopped so didn't know if the MPEM was for MP1.
Secondly I downloaded the zip version and extracted the DLL to a folder called Plugins (which I had to create) in C:\ProgramData\Team MediaPortal\MP2-Server this also caused the program to crash when opening.
2015-09-08, 08:39
I'm just going to run it from mediaportal till someone shows me how to connect it to kodi
2015-09-08, 08:40
Because I got Windows 10 so I can use mediaportal 2
2015-09-08, 10:55
It seems to me that mm1352000 (tvserver 3.5 programmer) has change something in the plugins. So, i think that until margro (mp pvr plugin developer) and mm1352000 talk each other it will be difficult to see a plugin for mp 2.0.
Already asked and waiting for that, because the new tvserver is really an improvement.
Bye,
sdf
Bye,
sdf
2015-09-08, 10:57
You know how long
2015-09-08, 21:57
I won't start on a plugin for 3.5 without any information about the things that need to be changed.
Others can help me if they want. The code can be found here:
https://github.com/margro/TVServerXBMC/t...ortal_1.10
I'm actually surprised that the old TVE3 crashes when using it together with MP2. As far as I know, it is the same TV server as used for MP1.
2015-09-08, 23:21
(2015-09-08, 10:55)sdfg Wrote: [ -> ]It seems to me that mm1352000 (tvserver 3.5 programmer) has change something in the plugins. So, i think that until margro (mp pvr plugin developer) and mm1352000 talk each other it will be difficult to see a plugin for mp 2.0.
Bye,
sdf
I was under the impression that TVE3.5 was not released yet. Is this wrong?
2015-09-09, 00:01
(2015-09-08, 21:57)margro Wrote: [ -> ]I'm actually surprised that the old TVE3 crashes when using it together with MP2. As far as I know, it is the same TV server as used for MP1.
That was my thinking, I don't know a lot about MP1 or MP2, but it looked like the server only install I did of MP2 had installed the MP1 TV server, so I would of thought the plug in would have worked, perhaps I went about installing it incorrectly (see post 7).
If you like I can install MP2 again and see what happens and post screen shots/logs, but please confirm the correct way to install the plug in - it was a long time ago that I set up MP1.
@mcelliott The MP2 Summer 15 release news article clearly states this.
Quote:TV support has been extended. Now we support both the known stable TV engine from MP 1 (aka TVE3) and its upcoming successor TVE 3.5 (which is currently at alpha stage).
When I installed MP2 there was no option to choose the TV Engine, perhaps thats under custom. The main reason I wanted to use MP2 was the advertised support for Media Centre WTV recordings, not that I worked out how to import them.
2015-09-09, 00:22
The TVE3 in MediaPortal 2 uses a SQLite database and not a full SQL server, that's probably one reason the Kodi plugin doesn't work anymore.
