Full Version: vdr didn't start right after S4
[/quote]I have a problem with my vdr. It didn't start right after hybernate S4.
Allways when I wake up my htpc I get the error can'f find vnsi-server.
so I tried to start vdr by using ssh and looked into the log
Oct 15 19:30:07 mediacenter vdr: [2878] VDR version 2.1.6 started
Oct 15 19:30:07 mediacenter vdr: [2878] switched to user 'vdr'
Oct 15 19:30:07 mediacenter vdr: [2878] codeset is 'UTF-8' - known
Oct 15 19:30:07 mediacenter vdr: [2878] found 28 locales in /usr/share/locale
Oct 15 19:30:07 mediacenter vdr: [2878] loading plugin: /usr/lib/vdr/plugins/libvdr-sc.so.2.1.6
Oct 15 19:30:07 mediacenter vdr: [2878] cTimeMs: using monotonic clock (resolution is 1 ns)
Oct 15 19:30:07 mediacenter vdr: [2878] [general.debug] using new 1.7.11+ capture code
Oct 15 19:30:07 mediacenter vdr: [2878] loading plugin: /usr/lib/vdr/plugins/libvdr-vnsiserver.so.2.1.6
Oct 15 19:30:07 mediacenter vdr: [2878] loading /etc/vdr/setup.conf
Oct 15 19:30:07 mediacenter vdr: [2878] loading /etc/vdr/sources.conf
Oct 15 19:30:07 mediacenter vdr: [2878] loading /etc/vdr/diseqc.conf
Oct 15 19:30:07 mediacenter vdr: [2878] loading /etc/vdr/scr.conf
Oct 15 19:30:07 mediacenter vdr: [2878] loading /etc/vdr/channels.conf
Oct 15 19:30:07 mediacenter vdr: [2878] loading /etc/vdr/timers.conf
Oct 15 19:30:07 mediacenter vdr: [2878] loading /etc/vdr/svdrphosts.conf
Oct 15 19:30:07 mediacenter vdr: [2878] loading /etc/vdr/keymacros.conf
Oct 15 19:30:07 mediacenter vdr: [2878] registered source parameters for 'A - ATSC'
Oct 15 19:30:07 mediacenter vdr: [2878] registered source parameters for 'C - DVB-C'
Oct 15 19:30:07 mediacenter vdr: [2896] video directory scanner thread started (pid=2878, tid=2896, prio=high)
Oct 15 19:30:07 mediacenter vdr: [2878] registered source parameters for 'S - DVB-S'
Oct 15 19:30:07 mediacenter vdr: [2878] registered source parameters for 'T - DVB-T'
Oct 15 19:30:07 mediacenter vdr: [2896] video directory scanner thread ended (pid=2878, tid=2896)
Oct 15 19:30:07 mediacenter vdr: [2897] video directory scanner thread started (pid=2878, tid=2897, prio=high)
Oct 15 19:30:07 mediacenter vdr: [2897] video directory scanner thread ended (pid=2878, tid=2897)
Oct 15 19:30:07 mediacenter vdr: [2878] probing /dev/dvb/adapter0/frontend0
Oct 15 19:30:07 mediacenter vdr: [2898] epg data reader thread started (pid=2878, tid=2898, prio=high)
Oct 15 19:30:07 mediacenter vdr: [2898] reading EPG data from /var/cache/vdr/epg.data
Oct 15 19:30:07 mediacenter vdr: [2878] [general.debug] capturing device 0/0 (subsystem ID dd010020)
Oct 15 19:30:07 mediacenter vdr: [2878] [general.debug] creating standard device 0/0
Oct 15 19:30:07 mediacenter vdr: [2878] new device number 1
Oct 15 19:30:07 mediacenter vdr: [2898] epg data reader thread ended (pid=2878, tid=2898)
Oct 15 19:30:08 mediacenter kernel: [12185.489967] I2C timeout
Oct 15 19:30:08 mediacenter kernel: [12185.489977] IRS 00000001
Oct 15 19:30:09 mediacenter vdr: [2878] DVB API version is 0x050A (VDR was built with 0x050A)
Oct 15 19:30:09 mediacenter vdr: [2878] frontend 0/0 provides DVB-S,DVB-S2,DSS with QPSK ("STV090x Multistandard")
Oct 15 19:30:09 mediacenter vdr: [2900] tuner on frontend 0/0 thread started (pid=2878, tid=2900, prio=high)
Oct 15 19:30:09 mediacenter vdr: [2878] probing /dev/dvb/adapter1/frontend0
Oct 15 19:30:09 mediacenter vdr: [2901] section handler thread started (pid=2878, tid=2901, prio=low)
Oct 15 19:30:09 mediacenter vdr: [2878] [general.debug] capturing device 1/0 (subsystem ID dd010020)
Oct 15 19:30:09 mediacenter vdr: [2878] [general.debug] creating standard device 1/0
Oct 15 19:30:09 mediacenter vdr: [2878] new device number 2
Oct 15 19:30:09 mediacenter kernel: [12186.491159] I2C timeout
Oct 15 19:30:09 mediacenter kernel: [12186.491169] IRS 00000001
Oct 15 19:30:10 mediacenter kernel: [12187.492311] I2C timeout
Oct 15 19:30:10 mediacenter kernel: [12187.492323] IRS 00000001
Oct 15 19:30:11 mediacenter kernel: [12188.493505] I2C timeout
Oct 15 19:30:11 mediacenter kernel: [12188.493515] IRS 00000001
Oct 15 19:30:12 mediacenter kernel: [12189.494663] I2C timeout
Oct 15 19:30:12 mediacenter kernel: [12189.494676] IRS 00000001
Oct 15 19:30:13 mediacenter kernel: [12190.495839] I2C timeout
Oct 15 19:30:13 mediacenter kernel: [12190.495849] IRS 00000001
Oct 15 19:30:14 mediacenter kernel: [12191.496991] I2C timeout
Oct 15 19:30:14 mediacenter kernel: [12191.496995] IRS 00000001
Oct 15 19:30:15 mediacenter vdr: [2878] frontend 1/0 provides DVB-S,DVB-S2,DSS with QPSK ("STV090x Multistandard")
Oct 15 19:30:15 mediacenter vdr: [2903] tuner on frontend 1/0 thread started (pid=2878, tid=2903, prio=high)
Oct 15 19:30:15 mediacenter vdr: [2878] found 2 DVB devices
Oct 15 19:30:15 mediacenter vdr: [2904] section handler thread started (pid=2878, tid=2904, prio=low)
Oct 15 19:30:15 mediacenter vdr: [2878] initializing plugin: sc (1.0.0pre-Unknown): Ein Software emuliertes CAM
Oct 15 19:30:15 mediacenter vdr: [2878] [general.info] SC version 1.0.0pre-Unknown initializing (VDR 2.1.6)
Oct 15 19:30:15 mediacenter vdr: [2878] initializing plugin: vnsiserver (1.2.0): VDR-Network-Streaming-Interface (VNSI) Server
Oct 15 19:30:15 mediacenter vdr: [2878] setting primary device to 1
Oct 15 19:30:15 mediacenter vdr: [2878] device 1 has no MPEG decoder
Oct 15 19:30:15 mediacenter vdr: [2878] assuming manual start of VDR
Oct 15 19:30:15 mediacenter vdr: [2878] setting current skin to "lcars"
I allways get this line...
any ideas?
Looks like something goes wrong in the lower layers. Does not surprise me because nobody uses hybernate nowadays. Wake from S4 is slower than from S5 in most of the cases.
Did this ever happen on boot from S5 or S3?
no, this only happend with hybernate...
Problrm is that most of the new mainbord don't support wakeup from S5 by using a IR
What a shame, isn't it. Seems most manufactures don't care much about the HTPC use case. I use my custom IR receiver + programmable timer device which I built myself because there is only crap on the market.
yes it is... I thinking about a y.a.r.d.2 or something like this... maybe this will help...
thanks for helping...
