Full Version: 60% of channels without EPG - DVB-S2
I'v got tvheadend 3.4 installed on a debian arm system.
It's more or less continuously running since 2 weeks now (current uptime 7 days).
I've got EPG for some german channels: BR, ARD, Arte, MDR, NDR, SWR, RBB
(Looks like all ARD channels)
Missing are all ZDF channels, as well as the commercial ones.
Is there any way to have more control over what is going on?
I found the menu Config/EPG/EPG Grabber. I disabled all XMLTV (internal grabber, external interfaces), because I understood this is a paid service.
I enabled all OTA-Grabbers, including "EIT: DVB Grabber"
What's PyEPG?
thanks,
Jan
xmltv shouldn't be a paid-for service, so don't rule that out. Have a look at the grabber scripts.
PyEPG is a Python-based EPG grabber that's currently tied to a UK metadata provider. TBH, I don't even know how well it's been maintained recently, so I'd ignore that.
For pure OTA EPGs (and I forget how tvh 3.4 works), check that there aren't any mux- or service-specific EPG settings. IIRC, there are checkboxes to disable/enable the EPG for each entry.
Ah, it's only tv_grab_eu_epgdata that requires paying.
Solved the problem using this guide:
Find_available_grabbers
I've got a conf file now:
/home/hts/.xmltv/tv_grab_eu_egon.conf
and it works!
