Full Version: OpenSubtitles AddOn\\ Subtitles not showing
Since I've upgraded to the latest build, when downloading subtitles from opensubtitles, although it seems the subtitles are downloaded Ok, it does not show on the screen while playing. I've looked through the debug log and this is the relevant lines:
Quote:21:54:25 T:3380 INFO: CPythonInvoker(35, C:\Users\Home Cinema\AppData\Roaming\XBMC\addons\service.subtitles.opensubtitles\service.py): script successfully run
21:54:25 T:3828 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
21:54:25 T:3828 DEBUG: CGUIDialogSubtitles::OnDownloadComplete - Saved subtitle C:\Users\Home Cinema\AppData\Roaming\XBMC\userdata\addon_data\service.subtitles.opensubtitles\temp\b53e2a87-b3eb-4300-b022-8687921e53cb.srt to special://temp/The lives of others 2006_ENGSUB.mkv.en.srt
21:54:25 T:3828 DEBUG: CUtil::GetExternalStreamDetailsFromFilename - Language = 'eng' / Name = '(External)' / Flag = '0' from special://temp/The lives of others 2006_ENGSUB.mkv.en.srt
21:54:25 T:2180 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
21:54:25 T:1084 NOTICE: Opening Subtitle stream: 0 source: 1024
21:54:25 T:1084 DEBUG: CFileCache::Open - opening <temp/The lives of others 2006_ENGSUB.mkv.en.srt> using cache
21:54:25 T:1084 ERROR: CFileCache::Open - failed to open cache
21:54:25 T:1084 ERROR: CDVDPlayerSubtitle::OpenStream - Unable to create subtitle parser
21:54:25 T:1084 WARNING: CDVDPlayer::OpenSubtitleStream - Unsupported stream 0. Stream disabled.
21:54:25 T:3380 INFO: Python script stopped
Any thoughts?
Anyone? This only happens when I'm streaming media from the web.
