Full Version: multiple live TV playlists?
hi folks.
Live TV newbie here. Using 13.2 on various platforms.
Somebody has given me their M3U playlist URL, which I have plugged into the PVR IPTV Simple Client and it all works fine! Live TV section comes up on xbmc main screen and it all works very well.
However now someone else has given me another M3U playlist URL which contains different channels and is also very good.
Is there anyway I can use BOTH playlists without having to edit the playlist URL in the PVR settings every time I wish to change between lists??
thanks for any help.
Ed, I would think that you should just combine both lists into one (I'd make a third list out of the two).
Thanks. Another add-on allows this though, it's called Playlist Loader
There are probably third-party tools for managing and merging playlists. The IPTV addon only supports one input file, there's not much that can be done about that.
