2014-10-30, 18:03
2014-10-30, 18:45
Short answer: No.
You could MAYBE add a second profile and set scraper to location "de" scrape that in german and see if that works, proefiles can have independant libraries from same sources, but idk how you get around the English titles only in source. SO likely no.
2014-10-30, 22:55
2014-10-31, 16:52
The XBMC database has in fact an option for a local title and original title. See: http://kodi.wiki/view/XBMC_databases#movie
I also remember that in a skin I used there was an option to show original or preferred title. Unfortunately I am not sure which skin that was. It might be Hybrid, Aeon Nox or Amber.
The Universal Movie scraper does have a setting to scrape a specific language or use the original title. I do not know whether it actually stores both in the database or just the preffered title. Also, even if it stores both, the search function doesn't seem to find both titles but perhaps another search tool is available that checks all database fields.
2014-10-31, 17:16
That's a scraper option and once our scraped your bound by what's in the library, so I still think you cant have two searchable working titles in dif languages for same movie. Even if its in the nfo that has to be put in a database to be searchable and goes around again. Anyway I doubt this is possible. But tbh I dont care enough to put any time on it.
2014-10-31, 17:19
Did you look at this?:
http://kodi.wiki/view/NFO_files/movies
There is a
<originaltitle>Who knows for real</originaltitle>
tag for the name in english for example
There is a
2014-10-31, 17:56
(2014-10-31, 17:19)David1977 Wrote: [ -> ]Did you look at this?:
There is a
Yeah, but that has to be supported by the skin. For instance Aeon MQ5 has an option to show the original title at the top, but having tested that with low list, it doesn't appear to work It might do in a different view though. Other skins probably have a similar option, which would then give you an english title and a german one at the same time.
2014-10-31, 18:19
Searches only work on lib content iirc right? So you cant have to names on the database?
2014-11-02, 16:48
2014-11-02, 23:14
I've not tryed, but you could maybe add your movies twice by creating simlinks of the movie with differents .nfo files ?
My movie.mkv
My movie.nfo
My movie original title.mkv (simlink -> My movie.mkv)
My movie original title.nfo
I use this method to have the same movie in differents directory (example : movies derivated from TV Shows that i would like to find both in Movies and in TV Shows, like Star Trek Movies)
My movie.mkv
My movie.nfo
