2014-10-30, 22:42
I've installed the lastest xbmcbuntu and updated. I am launching chrome with advanced launcher and the window fonts are huge (not the chrome content, but tabs and menus really). I guess it's openbox thing. Using nvidia gt610.
I have tried below, and changed the something larger, same...
I still see large fonts in chrome.
Any other things I could try? Thanks
Edit: solved
In /etc/lightdm/lightdm.conf, you can override the xserver-command parameter (which usually defaults to simply "X"). Here is mine:
xserver-command=X -dpi 96
xdpyinfo|grep dots
resolution: 96x96 dots per inch
/etc/xdg/lxsession/XBMCbuntu/desktop.conf by setting sGtk/FontName=Ubuntu 11
:~/.xbmc/addons$ cat /var/log/Xorg.0.log | grep -i dpi
[ 5.212] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 5.212] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 5.213] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 5.213] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 6.320] (--) NVIDIA(0): DPI set to (304, 304); computed from "UseEdidDpi" X config
Edit: solved
xdpyinfo|grep dots
