2014-10-31, 12:54
New user - any help greatly appreciated!
I have a UK Amazon Fire TV and have installed separately Gotham 13.2, SPMC and a recent nightly Kodi build via sideloading and have encountered the same buffering problem with all three different versions.
Everything seems to work wonderfully apart from a buffering issue when trying to play files (various different files attempted, usually between 1-2gb in size, 720p HD .mkv video files) from a local NAS drive using predominantly NFS (but also tried SMB).
This is not a problem with internet connection speed and upload / download buffering from a webstream. I have previously successfully streamed the same video files from the same NAS using Boxee box and a WDTV player with no buffering issues on same network, so I believe the issue is directly related to XBMC.
The files will play normally, then after a minute or so stop for buffering (for about 20 seconds). This repeats every five minutes or so which makes viewing very frustrating.
I have attempted various different buffer settings using advancedsettings.xml files - but nothing has done the job. The same buffering problem is encountered with XBMC, SPMC and Kodi.
I have managed to find a work around that does enable files to play without stopping to buffer, but would like to make things work perfectly in one variant of XBMC! Using the officially bought version of Plex and selecting media profile, external player and using SPMC files play perfectly with no buffering. I have noticed that when playing these files if I press the menu button on the remote in SPMC the debugging text shows on the fifth line (line beginning C( ad...) at the end shows for example "cache 20MB 100%". When playing files in SPMC without using Plex this cache number is always at 0b.
So, can anyone help with how to enable caching directly in SPMC/Kodi when playing network files from my local NAS storage to stop the buffering interrupting the video? (I'm a bit of a novice in terms of log files, especially from the AFTV but will try if given instructions! - thanks).
Many thanks
Many thanks
