if i switch channels kodi crashes sometimes. this happens only on some sd-channels (for instance sat1 or pro7, germany). with xbmc 13.2 all is working fine. if i switch streaming methode from "tsreader" to "ffmpeg" there ist no crash at channel change. (but with ffmpeg streaming methode timeshift isnt working). tested this on two different systems and there is another user who reports about this issue. here is a full debug log:
http://pastebin.com/z7fGQN5T
hello,
I can confirm this error.
Switching from "ARD HD" to "Pro Sieben HD" -> XBMC / KODI crash.
Switching from "ZDF HD" to "ARD HD" -> works.
With XBMC 13.2 everything is OK.
Sensman
Quote:18:35:59 T:6072 NOTICE: Creating teletext data thread
18:35:59 T:6072 ERROR: CThread::Create - fatal error creating thread- old thread id not null
Do you get the crash if you disable the teletext? -> Settings / Video / Playback / Uncheck
Activate Teletext
I can both confirm the error and I can also confirm that the error doesn't present itself with teletext turned off. So, it is a possible workaround.
ty ed67 for post in my thead.
i use kodi 14 beta 1 with MediaPortal 1.9.0 and TVServerXBMC plugin v1.6.0.125
and can comfirm the crashes since helix alpha
kodi crashed at all channel switches. sd to sd, hd to hd, sd to hd and last hd to sd.
i can confirm 13,2 works fine
deactivate teletext fix the problem and use now 14 beta 2
