how can i have the sound of navigation? i had it in experience 1080 beta before but now doesn't work
same here :-(
no skin sound.
This skin doesn't have sound. And you certainly didn't have it in any version since 2.0, unless it was a customised version.
How is it possible to add sound to this skin?
I find it strange to hear no sound.
Or is there no simple way?
This skin has no sounds, it's not hard to add them but they won't be in the main release.
Here's a place to start:
1) Go to skin.1080xf/sounds
2) Open sounds.xml
3) Edit the lines required to remove dummy options and include sound files.
Okay, perfect. Done.
I need that audio response :-)
(2014-12-28, 13:10)HansDampfHH Wrote: [ -> ]Okay, perfect. Done.
You can use the default sounds from Confluence or another skin.
