Full Version: where is the pvr-vnsi-addon for kodi?
I'm on Linux and update to Kodi beta... but now my vnsi-pvr-addon dosen't work
anymore... so I removed it an install again but without succeess...
sudo apt-get install xbmc-pvr-vdr-vnsi
than I tries as follow but also with no success...
sudo apt-get remove xbmc-pvr-vdr-vnsi
sudo ln -s /usr/lib/kodi /usr/lib/xbmc
sudo ln -s /usr/share/kodi /usr/share/xbmc
so how can i install the pvr-addon?
I built it for x64 last week, try here
https://drive.google.com/folder/d/0B0msd...lQdnc/edit
thanks for help...
I just figured out that one of the symlinks was wrong... now it works...
