2014-11-12, 01:12
2014-11-12, 01:23
Maybe sometimes xbmc/kodi misses something and that is when user inter-action is involved?
I can spot that!
Go to TMDB and the result of a search for that is:
http://thetvdb.com/?string=the+big+red&s...ion=Search
go to imdb and the result is this:
http://www.imdb.com/title/tt0080437/?ref_=nv_sr_1
so not sure of your question exactly?
EDIT - Sorry I put that in wrong forum. NO Nothing about this media manager :-( Strike me off your list. So sorry. My bad :-(
I can spot that!
2014-11-12, 18:49
well, we only save one "rating"... so... you can't.
2014-11-12, 22:06
Thanks, myron,
Sorry, I do not understand at all. It looks like you can chose between e.g. downloading the rating of IMDB or TMDB. That's not correct?
Thank you again.
Thank you again.
2014-11-13, 13:04
you can specify the scraper where the data comes from upon scraping.
once in your library, you will never know where the data came from..
2014-11-13, 22:14
Thank you, mlaggner.
Many thanks again.
Quote:once in your library, you will never know where the data came from..So, this rating - http://i.imgur.com/XzFSjQE.png - might come from TMDB and it might come from IMDB (or from somewhere else), is that correct? You cannot identify it.
Many thanks again.
