2014-11-15, 00:18
My info:
Apple TV2
ios 5.1.1 (kernel: Darwin 11.0.0)
Kodi 14.0-Alpha5 Git:2014-10-18-31ce987-dirty (Compiled: Oct 18 2014)
Install method: ssh'd via my iMac (27-inch, Late 2012) v10.10
I will be happy to include a log if its deemed necessary.
I've been using the Kodi Alpha builds successfully for quite a while now. Today while installing the build http://mirrors.xbmc.org/nightlies/darwin...r-atv2.deb. I received the following errors below: Both during & at the end of the installation I don't know if it means there is problem or not? Please advise... thank you
Apple-TV:~ root# rm -f *xbmc*.deb
Apple-TV:~ root# apt-get update
Hit http://dl.firecore.com Release.gpg
Get:1 http://apt.modmyi.com stable Release.gpg [198B]
Get:2 http://nitosoft.com Release.gpg [487B]
Get:3 http://apt.saurik.com ios/690.10 Release.gpg [189B]
Ign http://repo666.ultrasn0w.com ./ Release.gpg
Get:4 http://apt.thebigboss.org stable Release.gpg [198B]
Get:5 http://cydia.zodttd.com stable Release.gpg [189B]
Hit http://apt.awkwardtv.org stable Release.gpg
Get:6 http://apt.modmyi.com stable Release [1341B]
Hit http://nitosoft.com Release
Get:7 http://apt.saurik.com ios/690.10 Release [166kB]
Get:8 http://cydia.zodttd.com stable Release [1670B]
Get:9 http://apt.thebigboss.org stable Release [472B]
Err http://nitosoft.com Release
Ign http://mirrors.xbmc.org ./ Release.gpg
Ign http://repo666.ultrasn0w.com ./ Packages/DiffIndex
Ign http://dl.firecore.com Packages/DiffIndex
Get:10 http://nitosoft.com Release [295B]
Ign http://nitosoft.com Release
Get:11 http://apt.modmyi.com stable/main Packages/DiffIndex [53.3kB]
Ign http://nitosoft.com Packages/DiffIndex
Hit http://dl.firecore.com Packages
Hit http://nitosoft.com Packages
Get:12 http://cydia.zodttd.com stable/main Packages/DiffIndex [53.3kB]
Hit http://repo666.ultrasn0w.com ./ Packages
Get:13 http://apt.saurik.com ios/690.10/main Packages/DiffIndex [8684B]
Get:14 http://apt.thebigboss.org stable/main Packages/DiffIndex [48.9kB]
Get:15 http://apt.saurik.com ios/690.10/main 2014-10-23-1121.30+2014-11-12-1530.25.pdiff [1084B]
Get:16 http://apt.saurik.com ios/690.10/main 2014-10-23-1121.30+2014-11-12-1530.25.pdiff [1084B]
Get:17 http://apt.modmyi.com stable/main 2014-10-23-0946.10+2014-11-14-1518.09.pdiff [46.0kB]
Get:18 http://apt.saurik.com ios/690.10/main 2014-10-23-1121.30+2014-11-12-1530.25.pdiff [1084B]
Hit http://apt.awkwardtv.org stable/main Packages/DiffIndex
Get:19 http://cydia.zodttd.com stable/main 2014-10-23-0302.51+2014-11-14-0600.07.pdiff [20.5kB]
Get:20 http://apt.thebigboss.org stable/main 2014-10-22-1349.24+2014-11-14-1742.11.pdiff [33.5kB]
Get:21 http://apt.modmyi.com stable/main 2014-10-23-0946.10+2014-11-14-1518.09.pdiff [46.0kB]
Get:22 http://apt.modmyi.com stable/main 2014-10-23-0946.10+2014-11-14-1518.09.pdiff [46.0kB]
Get:23 http://cydia.zodttd.com stable/main 2014-10-23-0302.51+2014-11-14-0600.07.pdiff [20.5kB]
Ign http://mirrors.xbmc.org ./ Packages/DiffIndex
Get:24 http://apt.thebigboss.org stable/main 2014-10-22-1349.24+2014-11-14-1742.11.pdiff [33.5kB]
Get:25 http://mirrors.xbmc.org ./ Packages [602B]
Get:26 http://cydia.zodttd.com stable/main 2014-10-23-0302.51+2014-11-14-0600.07.pdiff [20.5kB]
Get:27 http://apt.thebigboss.org stable/main 2014-10-22-1349.24+2014-11-14-1742.11.pdiff [33.5kB]
Fetched 437kB in 22s (19.8kB/s)
W: GPG error: http://nitosoft.com Release: The following signatures were invalid: KEYEXPIRED 1387237030 KEYEXPIRED 1387237030 KEYEXPIRED 1387237030
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
Apple-TV:~ root# dpkg --configure -a
Apple-TV:~ root# wget http://mirrors.xbmc.org/nightlies/darwin...r-atv2.deb
--2014-11-14 11:26:15-- http://mirrors.xbmc.org/nightlies/darwin...r-atv2.deb
Resolving mirrors.xbmc.org... 89.16.176.16
Connecting to mirrors.xbmc.org|89.16.176.16|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: http://xbmc.os6.org/xbmc/nightlies/darwi...r-atv2.deb [following]
--2014-11-14 11:26:16-- http://xbmc.os6.org/xbmc/nightlies/darwi...r-atv2.deb
Resolving xbmc.os6.org... 64.90.58.16
Connecting to xbmc.os6.org|64.90.58.16|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 36629908 (35M) [application/x-debian-package]
Saving to: `kodi-20141113-78d666e-master-atv2.deb'
100%[=======================================>] 36,629,908 139K/s in 6m 19s
2014-11-14 11:32:35 (94.3 KB/s) - `kodi-20141113-78d666e-master-atv2.deb' saved [36629908/36629908]
Apple-TV:~ root# dpkg -i *xbmc*.deb
dpkg: error processing *xbmc*.deb (--install):
cannot access archive: No such file or directory
Errors were encountered while processing:
*xbmc*.deb
Apple-TV:~ root# dpkg -i *kodi*.deb
(Reading database ...
dpkg: serious warning: files list file for package `org.xbmc.kodi-atv2' missing, assuming package has no files currently installed.
8565 files and directories currently installed.)
Preparing to replace org.xbmc.kodi-atv2 14.0-0~alpha5 (using kodi-20141021-e235b13-master-atv2.deb) ...
Unpacking replacement org.xbmc.kodi-atv2 ...
Preparing to replace org.xbmc.kodi-atv2 14.0-0~alpha5 (using kodi-20141021-f683137-master-atv2.deb) ...
Preparing to replace org.xbmc.kodi-atv2 14.0-0~alpha5 (using kodi-20141101-b6c4fb6-master-atv2.deb) ...
Preparing to replace org.xbmc.kodi-atv2 14.0-0~alpha5 (using kodi-20141113-78d666e-master-atv2.deb) ...
More than one copy of package org.xbmc.kodi-atv2 has been unpacked
in this run ! Only configuring it once.
dpkg: dependency problems prevent configuration of org.xbmc.kodi-atv2:
org.xbmc.kodi-atv2 depends on org.xbmc.kodi-seatbeltunlock; however:
Package org.xbmc.kodi-seatbeltunlock is not installed.
dpkg: error processing org.xbmc.kodi-atv2 (--install):
dependency problems - leaving unconfigured
org.xbmc.kodi-atv2
Note: 1.When i received the error following entering the command ---Apple-TV:~ root# dpkg -i *xbmc*.deb. I took 100% unknowing chance and put *kodi*" in place of *xbmc*. Im not sure about the GPG error either.
2. At the end it did take me back to ATV2 home screen, but I can still open Kodi/xbmc normally and have issues with only a couple addons out of many.
3. I'm not sure if more info is needed... sorry if I've made errors in my judgement. And will promptly comply with anything you ask or need.
I greatly appreciate any help, thank you.
Apple TV2
*xbmc*.deb
org.xbmc.kodi-atv2
