Full Version: Loading channels problem
2014/11/16 10:48:30.404 ServerWMC started.
2014/11/16 10:48:30.435 Assembly version: 1.0.0.49, build: 1171
2014/11/16 10:48:30.435 Config file version: 92
2014/11/16 10:48:30.435 Build: Release
2014/11/16 10:48:30.435 Server MachineName: SEAN-PC
2014/11/16 10:48:30.435 OS: Windows 7 Service Pack 1 64-bit
2014/11/16 10:48:30.435 OS Version: 6.1.7601.65536
2014/11/16 10:48:32.011 Processor: AMD Phenom™ II X4 965 Processor
2014/11/16 10:48:32.027 Graphics: NVIDIA GeForce GTX 550 Ti
2014/11/16 10:48:32.027 -----------------------------------------
2014/11/16 10:48:32.027 Non-default Config Settings -------------
2014/11/16 10:48:32.042 isAutoStart: True >>Default: False
2014/11/16 10:48:32.042 Updates_AutoApplyUpdates: True >>Default: False
2014/11/16 10:48:32.042 -----------------------------------------
2014/11/16 10:48:32.042 MainWindow> Starting InitializeWorker
2014/11/16 10:48:32.151 RecService> Starting ------------------
2014/11/16 10:48:32.151 EPG> loading...
2014/11/16 10:48:32.151 EPG> opening store
2014/11/16 10:48:32.697 EPG> TV store opened OK
2014/11/16 10:48:32.713 EnumerateRecorders> Tuner Devices and TuningSpaces found:
2014/11/16 10:48:32.713 EnumerateRecorders> ContentRecorder: 0
2014/11/16 10:48:32.775 EnumerateRecorders> Device #0
2014/11/16 10:48:32.775 EnumerateRecorders> Name: Hauppauge WinTV 885 BDA Tuner/Demod, Space: ATSC
2014/11/16 10:48:32.775 EnumerateRecorders> Guid: 87fad08d-8525-47d6-b68a-ab4f07eeb547
2014/11/16 10:48:32.885 EnumerateRecorders> done
2014/11/16 10:48:32.900 GetLineUpsAndChannels> started
2014/11/16 10:48:33.181 GetLineUpsAndChannels> Total LineUps: 1, Total channels imported: 29
2014/11/16 10:48:33.181 GetLineUpsAndChannels> Channels found in database: 36
2014/11/16 10:48:33.181 GetLineUpsAndChannels> Ignored Channels> Blocked in WMC: 0, User hidden: 0
2014/11/16 10:48:33.181 GetLineUpsAndChannels> Strange Channels> Null space: 0, Out-of-range(ignored): 7
2014/11/16 10:48:33.181 GetLineUpsAndChannels> Radio Channels> TV(audio-only): 0, Presets: 0
2014/11/16 10:48:33.181 GetLineUpsAndChannels> RadioPresets> Registry: 0, Config: 0
2014/11/16 10:48:33.181 GetLineUpsAndChannels> Protected Channels> encrypted: 0, DRM: 0
2014/11/16 10:48:33.181 GetLineUpsAndChannels> Edited Channels> Callsigns: 0, Numbers: 0
2014/11/16 10:48:33.181 GetLineUpsAndChannels> Channel Groups> Found: 0
2014/11/16 10:48:33.181 GetLineUpsAndChannels> Ignored Channel Groups> Blocked in WMC: 0, Empty groups: 1
2014/11/16 10:48:33.181 GetLineUpsAndChannels> done
2014/11/16 10:48:33.181 EPG> loading done
2014/11/16 10:48:33.493 StartRecordingLibraryWatcher> recording library watcher started
2014/11/16 10:48:33.711 RecService> EventScheduler started
2014/11/16 10:48:33.711 DecoyManager> Timer started
2014/11/16 10:48:33.711 LoadGenreDict> 'GenreDict.xml' loaded OK
2014/11/16 10:48:33.727 CheckChannelIcons> Channel icons successfully processed: 0 (epg: 0, user: 0)
2014/11/16 10:48:33.727 RecService> -------------(DONE)----------------
2014/11/16 10:48:33.727 HandleFolders ------------------------------------
2014/11/16 10:48:33.743 Local WMC 'RecTV' folder: 'C:\Users\Public\Recorded TV', ShareStatus: OK
2014/11/16 10:48:33.743 Format: NTFS
2014/11/16 10:48:33.743 Stored Network 'Recorded tv' path:
2014/11/16 10:48:33.743 > Samba: smb://SEAN-PC/Users/Public/Recorded TV
2014/11/16 10:48:33.774 > UNC: \\SEAN-PC\Users\Public\Recorded TV, ShareStatus: OK
2014/11/16 10:48:33.774 HandleFolders -------------(DONE)----------------
2014/11/16 10:48:33.805 SocketServer> starting up SocketServer
2014/11/16 10:48:33.805 SocketServer> permission to access sockets granted
2014/11/16 10:48:33.805 SocketServer> socket object created
2014/11/16 10:48:33.821 SocketServer> The first listed ethernet interface will be used for client Wake On LAN target - use MACAddressOverride setting to change:
2014/11/16 10:48:33.836 SocketServer> [1] Interface: 'Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)' MAC: 6C:F0:49:1A:E3:BE
2014/11/16 10:48:33.836 SocketServer> started on port: 9080
2014/11/16 10:48:33.836 Worker::Init> MaintenanceTimer created
2014/11/16 10:48:33.836 InitializeWorker> successfully started: True
2014/11/16 10:48:33.836 MaintenanceTimer> callback at 10:48 AM
2014/11/16 10:48:33.852 Updater> Checking for updates...
2014/11/16 10:48:34.023 MaintenanceTimer> callback - complete
2014/11/16 10:48:34.055 MainWindow::Window_Loaded> not running as service, checking folder status.
2014/11/16 10:48:34.055 MainWindow::Window_Loaded> Done
2014/11/16 10:48:34.663 Current version still up to date.
2014/11/16 10:48:34.663 Updater> Current version 1.0.1171.0 is up to date
2014/11/16 10:48:34.663 Updater> Next check at 11/16/2014 2:00:00 PM
2014/11/16 10:48:49.250 Updater> Checking for updates...
2014/11/16 10:48:49.607 Current version still up to date.
2014/11/16 10:48:49.608 Updater> Current version 1.0.1171.0 is up to date
2014/11/16 10:50:23.273 Connected client: 'sean-PC', IP: 192.168.10.161, isRemote: False
2014/11/16 10:50:23.273 > addon/plugin Version: 0.2.99, Client OS: windows(6.1)
2014/11/16 10:50:23.276 > path to Rec Folder: 'C:\Users\Public\Recorded TV'
2014/11/16 10:50:23.283 Received client request: sean-PC|192.168.10.161|GetServerVersion|2014-11-16 15:50:23
2014/11/16 10:50:23.315 Finished request GetServerVersion in 0.03s
2014/11/16 10:51:32.936 Received client request: sean-PC|192.168.10.161|GetServerVersion|2014-11-16 15:51:32
2014/11/16 10:51:32.936 Finished request GetServerVersion in 0.00s
2014/11/16 10:51:33.039 Received client request: sean-PC|192.168.10.161|GetChannels|True
2014/11/16 10:51:33.052 Finished request GetChannels in 0.01s
2014/11/16 10:51:33.056 Received client request: sean-PC|192.168.10.161|GetChannelGroups|True
2014/11/16 10:51:33.062 Finished request GetChannelGroups in 0.01s
This is the complete log for the problem I have. When I start XBMC I get a window with message; PVR manager is starting up Loading channels from clients
Then nothing...it stays stuck and when I close XBMC it crashes.
BTW: I'am a newbie at this and thanks for the help
I think you might need to reset the xbmc database. Go to system>settings>livetv>general and then choose 'reset the pvr database'
Tried that just now...got to -10% and then XBMC crashed.
will try a fresh install of XBMC.
tried to do a clean install but I can't get it back to original setup....any idea how?
I'm not sure what you mean by the original setup.
OK...got to do a fresh install and reset PVR database 100% but I am still getting same results
The log is still the same as the one you posted? (btw, you should post logs on pastebin.com and put a link to it here)
Log still seems the same
http://pastebin.com/2MKktt1V
were you having this problem with the older version of swmc?
This looks to be a client side problem so can you please also generate an XBMC Debug Log and upload it for perusal?
Hope this will help and thanks for the input on this.
http://pastebin.com/CgZghkid
hmmm it doesnt throw any errors it just never makes any more calls after it loads the ChannelGroups and Channels for radio and tv... The XBMC log is pretty busy with all manner of things, like media scrapers looking through your download directory trying to scrape media information for zip files that arent even media etc... Are you certain this is how you want to have XBMC setup? Generally you should only have media files in the area you configure XBMC to have as it's media library etc... by using your general download directory it is looking at everything youve downloaded included applications, zip files etc etc,
For your particular problem I would suggest to disable LiveTV, shutdown XBMC. Start it up again (still in debug mode) and wait until the log settles down from all the library updates and so on.
Once the log is a bit quieter, perform a full reset of the PVR and EPG databases (under System->Settings->LiveTV->General and ->EPG) then re-enable LiveTV and the pvr.wmc addon. If it still doesnt load the channels etc, upload the log again and hopefully it will be a bit clearer this time without all the media updates etc going at the same time? You should also upload the ServerWMC log that matches the same time period/event sequence just for cross checking purposes
