2014-11-18, 01:22
Hello All,
i have three windows PC's using a shared MySql database on host 192.168.0.100:3306 and everything is working just fine however, whenever i try to add a Pi Raspbmc it does not use the database on my mySQL Server, but rather creates a new database.
MySQL Database
Videodb78 -> created by Pi
Videodb90 -> created by Windows Kodi
Music46 -> created by Pi
Music48 -> created by Windows Kodi
If i delete the pi databases from my mysql server and restart the PI, it will recreate them which is very odd.
If i attempt to add the name of the databases to the advancesettings.xml where names are Videodb90 and Music48, the pi will create a database with the following
Videodb9078
Music4846
[advancesettings.xml] -> Used for all my kodi installs (pi and windows)
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.0.100</host>
<name>videodb</name>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<name>musicdb</name>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</musicdatabase>
[RaspBMC Logs]
23:00:54 T:3037519872 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<network>
<readbufferfactor>4.0</readbufferfactor>
</network>
<imageres>540</imageres>
<fanartres>720</fanartres>
<video>
<defaultplayer>omxplayer</defaultplayer>
<defaultdvdplayer>omxplayer</defaultdvdplayer>
</video>
</advancedsettings>
23:00:54 T:3037519872 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
23:00:54 T:3037519872 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</musicdatabase>
<pathsubstitution>
<substitute>
<from>special://masterprofile/mediasources.xml</from>
<to>smb://192.168.0.100/cache/appdata/xbmc/userdata/mediasources.xml</to>
</substitute>
<substitute>
<from>special://masterprofile/profiles.xml</from>
<to>smb://192.168.0.100/cache/appdata/xbmc/userdata/profiles.xml</to>
</substitute>
<substitute>
<from>special://masterprofile/sources.xml</from>
<to>smb://192.168.0.100/cache/appdata/xbmc/userdata/sources.xml</to>
</substitute>
<substitute>
<from>special://masterprofile/upnpserver.xml</from>
<to>smb://192.168.0.100/cache/appdata/xbmc/userdata/upnpserver.xml</to>
</substitute>
<substitute>
<from>special://masterprofile/playlists/</from>
<to>smb://192.168.0.100/cache/appdata/xbmc/userdata/playlists/</to>
</substitute>
<substitute>
<from>special://masterprofile/keymaps/</from>
<to>smb://192.168.0.100/cache/appdata/xbmc/userdata/keymaps/</to>
</substitute>
<substitute>
<from>special://masterprofile/Thumbnails/</from>
<to>smb://192.168.0.100/cache/appdata/xbmc/userdata/Thumbnails/</to>
</substitute>
</pathsubstitution>
<useddsfanart>true</useddsfanart>
<network>
<disableipv6>true</disableipv6>
</network>
<videolibrary>
<dateadded>0</dateadded>
<importwatchedstate>true</importwatchedstate>
</videolibrary>
</advancedsettings>
23:00:54 T:3037519872 WARNING: VIDEO database configuration is experimental.
--> Here you can see the scanning for the DB's but it never looks for a videodb90
23:01:15 T:3037519872 DEBUG: Mysql commit transaction
23:01:15 T:3037519872 ERROR: Unable to open database: videodb78 [1049](Unknown database 'videodb78')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb77 [1049](Unknown database 'videodb77')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb76 [1049](Unknown database 'videodb76')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb75 [1049](Unknown database 'videodb75')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb74 [1049](Unknown database 'videodb74')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb73 [1049](Unknown database 'videodb73')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb72 [1049](Unknown database 'videodb72')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb71 [1049](Unknown database 'videodb71')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb70 [1049](Unknown database 'videodb70')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb69 [1049](Unknown database 'videodb69')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb68 [1049](Unknown database 'videodb68')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb67 [1049](Unknown database 'videodb67')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb66 [1049](Unknown database 'videodb66')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb65 [1049](Unknown database 'videodb65')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb64 [1049](Unknown database 'videodb64')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb63 [1049](Unknown database 'videodb63')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb62 [1049](Unknown database 'videodb62')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb61 [1049](Unknown database 'videodb61')
23:01:15 T:3037519872 ERROR: Unable to open database: videodb60 [1049](Unknown database 'videodb60')
Here its starting to create the 78 database for video's
23:01:15 T:3037519872 INFO: creating version table
23:01:15 T:3037519872 DEBUG: Mysql execute: CREATE TABLE version (idVersion integer, iCompressCount integer)
CHARACTER SET utf8 COLLATE utf8_general_ci
23:01:16 T:3037519872 DEBUG: Mysql execute: INSERT INTO version (idVersion,iCompressCount) values(78,0)
So i guess my question is why is the pi not even picking up the videodb90 database that exist on the mysql server. I assume because it does not find that database when its starting the scan, it creates a new one..
Versions:
Windows kodi 14.0 Beta 3
Pi: raspbmc using the newest download package from the website. ive even tried to install the nightly builds (RC1, Beta 1-4 and the lattest nightly build from the pi UI interface)
MySQL Database
Videodb9078
Music4846
<advancedsettings>
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</musicdatabase>
[RaspBMC Logs]
<advancedsettings>
<network>
</network>
<video>
</video>
</advancedsettings>
<advancedsettings>
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</musicdatabase>
<pathsubstitution>
<substitute>
</substitute>
<substitute>
</substitute>
<substitute>
</substitute>
<substitute>
</substitute>
<substitute>
</substitute>
<substitute>
</substitute>
<substitute>
</substitute>
</pathsubstitution>
<network>
</network>
<videolibrary>
</videolibrary>
</advancedsettings>
Versions:
