2014-11-18, 14:21
2014-11-19, 01:20
I'm not sure which .xml is responsible for the spinning disc for the "Now Playing" item in the main menu. However, the disc for the artist slideshow is found somewhere in "MusicVisualization.xml" in the Userdata/addons/skin/1080i folder. I'd suggest installing Notepad++ and doing a search for an items such as "disc.png" and deleting it. Then save MusicVisualization.xml and reload to test. Also, finding the actual image file in the skin/media folder and deleting it might also work.
2014-11-21, 13:03
Thanks for the advice Warner306
