2014-11-18, 22:37
I'm trying to move from MythTV frontend to Kodi for my LiveTV needs. But i find it hard to get it like i want it. So i have a few questions that i hope can get an answer.
1. Does anyone have a good remote keymap that they feel works? I find it hard to get things like i want with all the different windows and keybindings. Would be great to have a decent/good keymap to start with that is tweaked for PVR usage.
2. When i select TV now in Confluence the TVChannels screen open. Is it possible to:
a) have the last channel autostart in the little window?
or b) have the last channel start in fullscreen?
3. Is there some kind of import function to have all recorded shows appear in TVShows with fanart etc.? Or have fanart etc. in the recording window?
4. In FullscreenLiveTV, when i press Info, i get the channel name, progressbar, next show for the current channel. What i would like is that window(or similar) to show when i press up/down on my remote, and then be able to view next/previous channel that way, but only actual switch channel when i press OK, or abort if i press exit. The closest thing i can find now is pvrosdchannels, but i don't really need a list with all channels, and in that window i don't see the next show.
Maybe i'm a little bit stuck in how MythTV frontend handles things and i need to think different. But it is hard to change things you are used to. And as it is now i can't get it to work like MythTV frontend, and i'm not skilled enough to tweak everything to take advantage of all the things that Kodi can do that MythTV can't. Maybe with some help i can get a whole new TV experience much better than MythTV. Or is Kodi still a few steps behind when it comes to PVR?
