I really like this program, so donated, and was able to successfully register my donation. Once registered, I was instructed to restart the app, but it will not open. I've checked my security settings, which are ok, I uninstalled and reinstalled the app, none of which have worked.
Any suggestions ?
Thanks,
Tom
hmm.. have no clue.
Which OS?
Can you upload the logfile somewhere (or upload it
here)
mainly the /launcher.log and the /logs/tmm.log
OS is Mac OSX - Yosemite 10.10.1
I searched for the two log files, but was unable to locate either of them. Next step ?
Logs should be inside the app folder.
What java client do you have installed?
The apple one, or the latest available from Oracle?
Try in a command shell - the output from
So I looked, and have no app folder for TinyMediaManager. The logs are not present in the 'Applications' folder.
I copied and pasted the java --version from your post into the command shell, the result was "Could not create the Java virtual machine."
I'm not sure on which Java version I have, but I will try to locate the latest version from Oracle and install that, and try again....
I really appreciate the help, thanks !
Tom
woo hoo ! Success !
Updated Java, tried to open the app, and it worked perfectly !
Really, REALLY appreciate the help !
Thanks,
Tom
Glad it worked
Dunno what apple changed with 10.10, but it was not good...
(We need to announce this a bit better, to use a 'real' java version)
