2014-11-23, 23:30
I'm using Xbmc 13.1 on a STB (a9Cortex). I've just installed TVADDONS repo, and whenever I start XBMC i get their splash screen instead of the old XBMC one. I tried to change it from the media, but the Splash.png from the media it's the original one, the old XBMC, exactly the one I need to show at boot. There is not TVADDONS png splash in the media folder. I don't know where it resides or which settings or xml I should change.
Thank you.
Thank you.
