Full Version: Urgent help i think everything just reset
So i had to rearrange my entertainment system so i disconnected my box (black MX Box) Ethernet, etc and turned it back on and it takes the loading screen that says "MBOX" like a minute to load and than all of a sudden goes to the initial setup screen, the screen that asks for my internet connection type, lets me resize my screen, etc..... after doing this it brought me to the android app screen and no more "XMBC" App to click on.... So heres my questions....
1. What happened and why
2. How can i fix it (xbmc came preloaded on my box when i bought it)
3. How easy and where can i find instructions to do so... please help me asap cause this is my only source of entertainment (no cable, dish network, etc)...
thank you very much.
Reach out to the manufacturer or vendor.
This is the box i have and just to be clear the entire XBMC App is gone. this is what i think i need to do
hi have you tried this it worked for me
XBMC Re-Install Instructions
First we need to Reset the Unit.
1. Go to the screen with all the apps
2. Press Setup on your remote
3. Scroll to Backup & Reset
4. Click Factory Data Reset
5. Make sure no sd cards or usb sticks are plugged into box
6. Click Reset Media Box
7. Click Erase Everything
8. Wait for box to reboot and give you the Welcome Wizard again.
You need to download XBMC
9. On your media player go to browser in apps
9a. Press the cursor key (bottom right bottom remote control) type the following link: http://xbmc.org/download/
10. Once here click on the android logo and your download will begin
Installing XBMC
11. Goto Downloads in Apps
12. Double click XBMC (This will install XBMC to your unit)
XBMC
13. On the screen with all the apps now click on XBMC (Takes 30 seconds)
14. Scroll to System and click on it
15. Scroll to System tab and click on it
16. Scroll to Input Devices and click on it.
17. Make sure Remote Control sends keyboard presses is highlighted.
18. Now press menu until you are back at the main XBMC menu
