Full Version: Aeon Nox 5, Kodi beta 4 UI freezes
Using the latest Kodi 14 beta 4, whenever I browse "System - Add Ons - Enabled addons - ..." the UI freezes at some point and I have to force quit Kodi. It is reproducable on my system and I can trigger it by just browsing that menu item for long enough. At some point it will freeze. This doesn't seem to happen with the default skin enabled, so I decided to post this here instead of in the general support section. Feel free to move in case you find it appropriate. I am not certain if this also happened with previous betas (Kodi).
Hardware:
Model Name: MacBook Pro
Model Identifier: MacBookPro7,1
Memory: 4 GB
Boot ROM Version: MBP71.0039.B0E
SMC Version (system): 1.62f7
debug log
Regards, F
Not a Nox problem, but a beta 4 problem. See:
http://forum.kodi.tv/showthread.php?tid=209628
Allright. Guess this thread can be ignored then. Apparently my search foo failed me when I checked if someone else reported this already.
Thanks for the quick reply Smile
Regards, F
