Full Version: XBMC 13.2 keeps forgetting which shows I've seen
I've got a htpc that streams from a file server. For some reason, every now and then, XBMC will lose the data on which shows I've watched. It's extremely annoying and I don't even know how to start to figure out what's causing it.
I'm also using xbmc backup and I have a backup from two days ago but I'm not sure how to restore or if the watched shows data is even there.
I'll work on getting logs up on here in a bit.
Try Trakt addon and get a free account at Trakt.tv It should fix your problem.
PS. are you the same sp00ky from another forum who used to be called sp00kster or sp00ky2?
I followed directions on enabling debug and how to upload. My issue is that the problem has already happened and only happens once a month or so with no set pattern.
(2014-11-26, 14:17)RavRob Wrote: [ -> ]Try Trakt addon and get a free account at Trakt.tv It should fix your problem.
I'll look into that for sure. Does it save your watched data to a service? I'm not the other two.
