Hi I have download this skin but the settings don't work and I want to revert back to the standard skin. I have tried deleting xbmc from cydia and reinstalling it, but when I install it again it keeps all my Addons and my skin :|
Any help would be much apriciated
Cheers
Jon
(2014-11-25, 20:29)And1_e30 Wrote: [ -> ]Hi I have download this skin but the settings don't work and I want to revert back to the standard skin. I have tried deleting xbmc from cydia and reinstalling it, but when I install it again it keeps all my Addons and my skin :|
Cheers
Jon
Which one You downloaded? sio2x or sio2?
You need to delete your guisettings.xml
probably by ssh(-ing) into iOS from another machine.
what exactly do you mean by "the settings don't work"?
you can't click them? or You don't see them? or nothing happens when you click on them?
I don't have a jailbroken iOS device so I can't test..
try connecting to the device via ssh and clean guisettings.xml
check this:
http://kodi.wiki/view/Userdata
I believe the path for the file you need to erase is:
/private/var/mobile/Library/Preferences/XBMC/userdata/
hope that helps.
Ok cheers I will try that
yeh nothing happens when clicking on settings. Tbh I can't remember I think it's was sio2x. I like the skin but as I can't go on settings and it's not that responsive I would like to go back to standard for the moment. Can you find the skin in I file or Not? I'm on holiday atm so only have the iPad
Cheers
Jon
(2014-11-25, 20:57)And1_e30 Wrote: [ -> ]it's not that responsive I would like to go back to standard for the moment. Can you find the skin in I file or Not?
i believe you can
look for the path i posted...
let me know.
Yeh it worked mate cheers
it was sio2. Do you know if sio2x fully works on ios?
Cheers
Jon
(2014-11-25, 21:07)And1_e30 Wrote: [ -> ]Yeh it worked mate cheers it was sio2. Do you know if sio2x fully works on ios?
Cheers
Jon
gotta admit I got NO IDEA
if you wish to test it.. pleas do and let me know... I'm willing to try and make it work. but i do need some feedbacks.
glad you fixed.
enjoy kodi. best piece of software around. (beside photoshop of course.)
