2014-11-26, 23:16
Hi, I have an issue with the shutdown menu. If I bring up the popup it only shows Exit, everything else is missing (well, settings and favourites are there but I'm sure that's because of the skin). In the home screen menu of my skin (Aeon Nox 5) I can see all options, but whichever I choose the result is the same as Exit.
At first I assumed that I just messed up a setting while using the remote to power off with the TV turned off, but in the settings under shutdown functions I cannot change anything, I have two values to choose from: ?0? and ?-1?
Any ideas what could be wrong? Thanks!
