Full Version: How to stop LyricsCU from starting *every time* I go fullscreen?
I'm running a NOx skin called "Aeon NOx Gotham Plus 4.1.9.9".
I also have NOx MQ5 installed.
Basically every time I hit fullscreen (music), the lyrics addon auto-starts. I don't want it.
So I tried to 'disable' in addons. ---- has no effect, lyrics still start.
So I thought OK, I'll 'uninstall' it, but it can't be uninstalled, giving an error saying it's being used by mq5 and can't be uninstalled.
I don't really want to uninstall MQ5 entirely..... Is there anything I can do?
regards.
go to activated addons -> lyricscu settings and disable start as service. that should help. best regards. fred.
Thanks for trying to help Fred, but basically dialing it does nothing.
It seems to be attached top the install of mq5.
It can't be uninstalled without also uninstalling mq5. Real bummer.
The other thing you could do is go into your addons Kodi folder and then delete the folder for lyricscu. It should be script.lryicscu or something similar. Then restart Kodi and it will not start on fullscreen.
If your problem is with Aeon MQ, why do you post in Nox subforum then? Huh
