2014-11-30, 11:01
Hi folks, is there yet a way to fully remove XBMC and re-install Kodi without having to re-install XBMC first (XBMC has been on there for quite a while now and crashes frequently)?
I followed the Wiki last night but first had a problem with a missing dependency which was fixed with "apt-get -f install" (After "apt-get update").
Once this was sorted I updated to the latest nightly build which gave me both a left over XBMC icon and the new Kodi icon on the Apple TV 2 springboard, the XBMC icon was removed with "apt-get remove org.xbmc.xbmc-atv2" but is there a way I can go straight to Kodi yet?
Would it be as easy as replacing this...
For this...
This is the complete install guide I followed.
Does this look correct for Kodi?
Many thanks
apt-get install org.xbmc.xbmc-atv2
For this...
apt-get install org.xbmc.kodi-atv2
apt-get install wget
wget -O- http://apt.awkwardtv.org/awkwardtv.pub | apt-key add -
echo "deb http://apt.awkwardtv.org/ stable main" > /etc/apt/sources.list.d/awkwardtv.list
echo "deb http://mirrors.xbmc.org/apt/atv2 ./" > /etc/apt/sources.list.d/xbmc.list
apt-get update
mkdir -p /Applications/AppleTV.app/Appliances
mkdir -p /Applications/XBMC.frappliance
reboot
apt-get update
apt-get -f install
mkdir -p /Applications/Kodi.frappliance
reboot
Many thanks
