Hi all,
I've created a modified version of this awesome skin.
It's based off of version 4.5.5.
Changes from the original skin:
- Support for 3rd-party: Skin Widgets, Next Aired, Artwork Downloader & more
- Improvements in customization options
- The Skin Settings interface follows the system settings' layout and design
- Various tweaks, check changelog.txt for complete list
watch gallery
More details in the
README
Download:
Install my repo
from there, if doesn't work (let me know! and then- ) download the skin directly from
here or
here.
Feedback is welcome of course!
thank you very much! everything quartz related is nice indeed!
You are getting better and better mate
Does it work with latest kodi raspberry pi release?
(2014-12-08, 14:45)pecinko Wrote: [ -> ]You are getting better and better mate
Thanks, that means a lot coming from the creator of the base skin
(2015-01-01, 16:12)Haris1977 Wrote: [ -> ]Does it work with latest kodi raspberry pi release?
Sorry to say what it's not tested on Kodi 14 Helix...
For now, I haven't received much feedback on this mod, so I don't see a reason to start testing.
If more people show interest I will consider a full code review.
(welcome to
fork on github and create pull requests, of course!)
Longtime user of Quarts (especially like the recently added movies list).
I moved to Kodi and although it works I assume there are some updates that are needed.
Would love to have Quartz Kodi compatible as well (iOS)
this looks wonderful, especially the shelf items themes for tv shows! I do have a request... can you make it Kodi compatible? (installing from the zip from your github page gave me a "dependencies not met" error)
(2015-01-21, 18:43)mediumdry Wrote: [ -> ]this looks wonderful, especially the shelf items themes for tv shows!
Thank you! The TV items themes was the initial reason I started modding in the first place... I'm glad you like it
(2015-01-21, 18:43)mediumdry Wrote: [ -> ]installing from the zip from your github page gave me a "dependencies not met" error
This skin requires only two add-ons:
Favourites and
Skin Widgets. Make sure you have those installed.
I suspect that when installing from a zip (rather than from an online repo), Kodi doesn't try to auto-install dependencies.
From the wiki:
Quote:When a user installs your add-on from an online repository via XBMC's add-on manager, XBMC attempts to resolve these dependencies, and install anything that your add-on relies on first
In case there is more support and demand for v14 support, I will try to find the time to do a complete overhaul.
Unfortunately, on Kodi, even with the two dependencies installed, it won't install from the zip. I would love it if you can try to make a Kodi compatible version, but I understand the work that goes into that..
I just turned on debug logging and on looking in the log, the only relevant lines are these:
20:01:04 T:140735141077760 DEBUG: ------ Window Deinit (FileBrowser.xml) ------
20:01:04 T:140735141077760 DEBUG: GetZipList - Processing zip://%2fUsers%2fkodi%2fDownloads%2fskin.quartz.mod-master.zip/
20:01:04 T:140735141077760 DEBUG: Addon skin.quartz.mod requires xbmc.gui version 5.0.1 which is not available
20:01:04 T:140735141077760 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
Is xbmc.gui version 5.0.1 related to Gotham?
For completeness sake:
20:00:15 T:140735141077760 NOTICE: Starting Kodi (14.0 Git:2014-12-23-ad747d9-dirty). Platform: OS X x86 64-bit
20:00:15 T:140735141077760 NOTICE: Using Release Kodi x64 build
20:00:15 T:140735141077760 NOTICE: Kodi compiled Dec 23 2014 by Clang 4.2 (clang-425.0.27) for OS X x86 64-bit version 10.6.0 (1060)
20:00:15 T:140735141077760 NOTICE: Running on Apple Inc. MacBookAir6,2 with OS X 10.10.2, kernel: Darwin x86 64-bit version 14.1.0
(2015-01-27, 21:06)mediumdry Wrote: [ -> ]I just turned on debug logging and on looking in the log, the only relevant lines are these:
Looking at the code for xbmc.gui addon:
https://github.com/xbmc/xbmc/blob/master.../addon.xml
I can see there's backwards compatibility only until 5.3.0
Since I'm requiring 5.0.1, that causes the failed install.
I will have to look into this myself in greater depth to check for other errors.
In the meantime, you're welcome to experiment a little and help with testing...
Here's a
link to a test addon, after changing the xbmc.gui requirement to 5.3.0. Let me know how it works!
EtgarDizz, any chance you're going to look into Kodi/Helix support?
