2014-12-12, 03:00
So I'm actually trying to use ServerWMC in conjunction with Media Browser and not Kodi, but I'm hoping someone can still assist. When attempting to initiate a stream or recording from Media Browser ServerWMC throws the error attached below. I've verified that there is no issue accessing the Recorded TV path, and I can't seem to find anything quite like this error on either the Media Browser or Kodi/ServerWMC forums. If anyone has any ideas I would greatly appreciate it. This was on a brand new install of Media Browser (3.0.5445.6) and Server WMC (1.0.0.52 build 1175). I am running ServerWMC as an application (not a service) and tried running as an administrator just in case it was a permissions issue.
2014/12/11 17:17:52.107 Received client request: MediaBrowser^@MEDIAPC@10|::1|OpenLiveStream|1163973|IncludeStreamInfo
2014/12/11 17:17:52.107 OpenLiveStream> -----------------start------------------------
2014/12/11 17:17:52.107 OpenLiveStream> client: MediaBrowser^MEDIAPC requesting live stream
2014/12/11 17:17:52.107 LiveRemuxStream> live-tv started
2014/12/11 17:17:52.107 SetChannel> Channel: 54 : AMC - 12BC = { (54 : AMC - 9AF) + [ 54 : AMC - 113A, 54 : AMC - 12BA] }
2014/12/11 17:17:52.107 SetChannel> Tuners available for this channel: 2
2014/12/11 17:17:52.107 SetChannel> Tuner DecoyMethod: OnDemand
2014/12/11 17:17:52.107 SetChannel> ---
2014/12/11 17:17:52.107 SetChannel> Attempt: 0, Tuner: Hauppauge WinTV-7164 Analog TV Tuner #1 / 52cd27f8-392a-4551-a84d-b1130bbccd35
2014/12/11 17:17:52.107 SetChannel> > Encrypted: False
2014/12/11 17:17:52.107 SetChannel> > RecorderInfo found: True
2014/12/11 17:17:52.107 SetChannel> > Recorder Content Protection: PROT_COPY_FREE
2014/12/11 17:17:52.107 SetChannel> > Status: Available, client:
2014/12/11 17:17:52.107 SetChannel> *** requested number of available tuners found, stopping search ***
2014/12/11 17:17:52.107 SetChannel> available tuners found: 1 [decoys:0], requested: 1, searched: 1
2014/12/11 17:17:52.107 SetChannel> Tuner: Hauppauge WinTV-7164 Analog TV Tuner #1 will be used for the live stream
2014/12/11 17:17:52.115 SetChannel> Recorder acquired: True
2014/12/11 17:17:52.115 SetChannel> TuneRequest set
2014/12/11 17:17:52.115 RecordToWTV::Close> isPassive is False => COM recorder will be stopped
2014/12/11 17:17:52.115 Record> Error: System.Runtime.InteropServices.COMException (0x80004005): A COM interop call failed. ---> System.UnauthorizedAccessException: Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
Server stack trace:
at ehiProxy.IRecorder.SetContentRecordName(String wzFilename, IMSVidStreamBufferRecordingControl& ppRecordingIUnknown)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData)
at Microsoft.MediaCenter.Pvr.RecorderAsyncWrapper.SetContentRecordNameDelegate.EndInvoke(IMSVidStreamBufferRecordingControl& ppRecordingIUnknown, IAsyncResult result)
at Microsoft.MediaCenter.Pvr.RecorderAsyncWrapper.SetContentRecordName(String wzFileName)
at ServerWMC.Worker.RecordToWTV.Record()
2014/12/11 17:17:52.115 LiveRemuxStream> process start error: Record> Can't start recording calling Close()
2014/12/11 17:17:52.115 LiveRemuxStream::Close> closed in 0.00 sec
2014/12/11 17:17:52.115 OpenLiveStream> error: Record> Can't start recording
2014/12/11 17:17:52.115 Finished request OpenLiveStream in 0.01s
Server stack trace:
