Full Version: TMM can't re-read .nfo files altered by "NFO Watchedstate Updater"
Hey there,
when you scrape movie-items with TMM, after "NFO Watchedstate Updater" changes them (barely), TMM can't re-read the .nfo files.
I narrowed the problem down to this (simplified example!):
.nfo file from TMM scraping:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<!-- created on 2014-12-14 15:12:30 - tinyMediaManager 2.6.4 -->
<movie>
    <title>A MovieName here</title>
    <originaltitle>A MovieName here</originaltitle>
    <set></set>
    <sorttitle></sorttitle>
    <rating>6.8</rating>
    <year>2013</year>
    <top250></top250>
    <votes>464</votes>
    <outline>Text Text Text Text Text Text Text Text Text Text Text Text Text</outline>
    <plot>Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text Text</plot>
    <tagline>Text Text Text Text </tagline>
    <runtime>116</runtime>
    <thumb></thumb>
    <mpaa>DE:FSK 16 / DE:FSK16 / DE:16 / DE:ab 16</mpaa>
    <certification>DE:FSK 16 / DE:FSK16 / DE:16 / DE:ab 16</certification>
    <id>11111111111111111111</id>
    <ids>
        <entry>
            <key>tmdbId</key>
            <value xsi:type="xs:int" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">1111111111</value>
        </entry>
        <entry>
            <key>imdbId</key>
            <value xsi:type="xs:string" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">1111111111</value>
        </entry>
    </ids>
    <watched>false</watched>
    <playcount>0</playcount>
</movie>
.nfo file alfter altering and cleanup from "NFO Watchedstate Updater":
<?xml version='1.0' encoding='UTF-8'?>
<movie xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <set />
  <sorttitle />
  <year>2013</year>
  <top250 />
  <votes>464</votes>
  <thumb />
  <ids>
    <entry>
      <key>tmdbId</key>
      <value xsi:type="xs:int">1111111111</value>
    </entry>
    <entry>
      <key>imdbId</key>
      <value xsi:type="xs:string">1111111111</value>
    </entry>
  </ids>
  <watched>true</watched>
  <playcount>1</playcount>
</movie>
FIX:
It all comes down to the two attributes:
If i remove
xsi:type="xs:int"
and
xsi:type="xsConfusedtring"
the .nfo file can be read by TMM again.
TMM error:
Quote:20:18:17.037 ERROR o.t.core.movie.connector.MovieToXbmcNfoConnector - getData
java.lang.IllegalArgumentException: prefix xs is not bound to a namespace
at com.sun.xml.internal.bind.DatatypeConverterImpl._parseQName(Unknown Source) ~[na:1.8.0_25]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.XsiTypeLoader.parseXsiType(Unknown Source) ~[na:1.8.0_25]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.XsiTypeLoader.startElement(Unknown Source) ~[na:1.8.0_25]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallingContext._startElement(Unknown Source) ~[na:1.8.0_25]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallingContext.startElement(Unknown Source) ~[na:1.8.0_25]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.SAXConnector.startElement(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source) ~[na:1.8.0_25]
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source) ~[na:1.8.0_25]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(Unknown Source) ~[na:1.8.0_25]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(Unknown Source) ~[na:1.8.0_25]
at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(Unknown Source) ~[na:1.8.0_25]
at org.tinymediamanager.core.movie.connector.MovieToXbmcNfoConnector.parseNFO(MovieToXbmcNfoConnector.java:726) ~[tmm.jar:2.6.4 (r1770)]
at org.tinymediamanager.core.movie.connector.MovieToXbmcNfoConnector.getData(MovieToXbmcNfoConnector.java:543) ~[tmm.jar:2.6.4 (r1770)]
at org.tinymediamanager.core.movie.tasks.MovieUpdateDatasourceTask.parseMovieDirectory(MovieUpdateDatasourceTask.java:400) [tmm.jar:2.6.4 (r1770)]
at org.tinymediamanager.core.movie.tasks.MovieUpdateDatasourceTask.access$100(MovieUpdateDatasourceTask.java:67) [tmm.jar:2.6.4 (r1770)]
at org.tinymediamanager.core.movie.tasks.MovieUpdateDatasourceTask$FindMovieTask.call(MovieUpdateDatasourceTask.java:881) [tmm.jar:2.6.4 (r1770)]
at org.tinymediamanager.core.movie.tasks.MovieUpdateDatasourceTask$FindMovieTask.call(MovieUpdateDatasourceTask.java:853) [tmm.jar:2.6.4 (r1770)]
at java.util.concurrent.FutureTask.run(Unknown Source) [na:1.8.0_25]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [na:1.8.0_25]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.8.0_25]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.8.0_25]
at java.lang.Thread.run(Unknown Source) [na:1.8.0_25]
Thanks Smile
thanks for the info. I'll put a workaround in the next version
Manuel
Great, thank you!
Hey there again,
just out of interest, will there be a last version pushed out within this year which contains the workaround? Smile
No hurry!
I hope so Smile
till XMAS we have very little time (work & family), but I hope I have some more time after XMAS to work on tmm
Alright, thanks. Take the time you need. Smile Merry XMAS.
Hey there,
just tried the pre-release, reinitialized the database and still getting many .nfo which can't be read. Possibly because of the thing we talked about here.
Question: Is the fix in the 2.6.5 prerelease? Or am i trying too soon?
Will provide more info. Smile
Follow up:
Just tried removing the two attributes like mentioned in my initial post. - and tada - works again.
So it seems that if there is a possible fix in 2.6.5, it doesn't seem to work?
Thanks anyway, we will sort this out! No hurry! Smile
Let me know if you need more info.
Essentially everything i tested some minutes ago is still the same as what i described in my first post.
You are right - the fix I've included was not good enough. in the next prerelease there will be a (hopefully) working fix Big Grin
stay tuned
Thanks! I'll report back.
Quick feedback. Updated last night and although i only did a short test, it seems to work now! Smile Thanks
Still looking good. Did some more tests.
