2014-12-19, 00:18
2014-12-19, 00:42
Change the location of the menu items and I believe the third enabled item is the one that appears on startup.
2014-12-19, 00:56
(2014-12-19, 00:42)mikesilvo164 Wrote: [ -> ]Change the location of the menu items and I believe the third enabled item is the one that appears on startup.
Thank you :]
2014-12-19, 03:48
Just use system-skin settings-customizer-general skin settings-set focus on startup
2015-01-04, 15:03
Using Helix with Aeon Nox
I noticed that the home menu item that is focussed upon startup will lose its focus when "Update library at startup" is activated. I assume that the focus is set on the update status window while it is updating but not given back to the home menu item when the update is done. Not sure if this is Kodi or Skin related. It's not a major flaw but it would be more convenient if the focus was given back to the home menu.
