2014-12-19, 17:10
Hi all,
My current 52" Samsung LCD TV is attached to my HTPC which is about 7-8' away from the seating position. At normal resolutions i.e. 1080p set in the HTPC the fonts and everything else is minuscule, currently i have set the screen resolution at 1440 x 900 @ Monitor settings 75 Hertz, Colors set to True Color 32 bit. The HTPC has a dedicated ATI 2GB HD7850 GPU. Also, i have set the text and other options to be at 150% in the display screen resolutions option.
Its only then one can look at the screen without straining the eyes.
I have also set the chrome browser to be 125% larger in font size under advance settings.
I think all this is an over kill, as everything in the browser makes off and unaligned. My XBMC is also showing its running at 1440 x 900 resolution.
Please advice, what are the best options that you guys use when using a large LCD at a distance with their HTPC.
I also have the catalyst control center for my ati gpu, is there configuration changes that needs to be done there as well?
