Full Version: Could I run kodi on any of these headless servers?
http://www.kijiji.ca/v-servers/markham-y...nFlag=true
My server that I use to stream media and have XBMC on (for addons, media scanning) has only 2 GB of memory and I'm looking to upgrade.
I plan on running some sort of linux distro on whatever I get, these are cheap so I'm wondering if Kodi will run on them even with no monitor connected?
They will work great. Gotta mount them though
Do you know how large/heavy those units are? Have you worked with rackmounted equipment before? They are very loud/large/heavy
But will xbmc run without a monitor hooked up?
For use as an HTPC don't bother.
If you want the server for other purpose such as file/disk storage then go for it.
