I newby in XBMCubuntu.
Is there a manner to restart the playlists, for example video or music?
I still want to see the first video after watching the last video in the list.
Thanks in advance
I only know a way if you got a playlist that starts at startup/boot:
https://github.com/1977David/xbmc/blob/m...up.xml#L18
The playlist which starts is a playlist containing some MP3 files, which I want to play randomly. The line I linked to is the part, where the player is controlled to repeat this playlist, if the last file is played. I donĀ“t know where a normal playlist is controlled, but if you start a playlist (for example a music playlist) and switch to the home screen you will find controll buttons (start, stop, pause, fwd, rwd, next and previous)....on the left side of these buttins there is a button called "full screen". If you click on this, the full screen will come up and with this a complete OSD with a repeat button. If you select this it works for me. Tested with confluence skin. It may be skin dependend, so I would first try with confluence, so you know where to look for and then compare with other skins.
Hope it helps a bit
Greetings
David
