Full Version: Bug? Error quitting Kodi while library is updating
Hi today I stumples over maybe a bug ...
While my system was updating the library I was browsing through my music files I did quit Kodi by cmd+q.
Then MacOS showed up an error box.
Any hints?
Michi
Content of kodi.log:
Quote:16:38:50 T:140735276151552 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:38:50 T:140735276151552 NOTICE: -----------------------------------------------------------------------
16:38:50 T:140735276151552 NOTICE: Starting Kodi (14.0-RC3 Git:2014-12-08-bdf56d0-dirty). Platform: OS X x86 64-bit
16:38:50 T:140735276151552 NOTICE: Using Release Kodi x64 build
16:38:50 T:140735276151552 NOTICE: Kodi compiled Dec 8 2014 by Clang 4.2 (clang-425.0.27) for OS X x86 64-bit version 10.6.0 (1060)
16:38:50 T:140735276151552 NOTICE: Running on Apple Inc. MacBookPro5,2 with OS X 10.10.1, kernel: Darwin x86 64-bit version 14.0.0
16:38:50 T:140735276151552 NOTICE: Host CPU: Intel® Core™2 Duo CPU T9800 @ 2.93GHz, 2 cores available
16:38:50 T:140735276151552 NOTICE: special://xbmc/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
16:38:50 T:140735276151552 NOTICE: special://xbmcbin/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
16:38:50 T:140735276151552 NOTICE: special://masterprofile/ is mapped to: /Users/michaelmuller/Library/Application Support/Kodi/userdata
16:38:50 T:140735276151552 NOTICE: special://home/ is mapped to: /Users/michaelmuller/Library/Application Support/Kodi
16:38:50 T:140735276151552 NOTICE: special://temp/ is mapped to: /Users/michaelmuller/.kodi/temp
16:38:50 T:140735276151552 NOTICE: special://frameworks/ is mapped to: /Applications/Kodi.app/Contents/Libraries
16:38:50 T:140735276151552 NOTICE: The executable running is: /Applications/Kodi.app/Contents/MacOS/Kodi
16:38:50 T:140735276151552 NOTICE: Local hostname: michaels-mbp
16:38:50 T:140735276151552 NOTICE: Log File is located: /Users/michaelmuller/Library/Logs/kodi.log
16:38:50 T:140735276151552 NOTICE: load settings...
16:38:50 T:140735276151552 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
16:38:50 T:140735276151552 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
16:38:50 T:140735276151552 NOTICE: Found 1 Lists of Devices
16:38:50 T:140735276151552 NOTICE: Enumerated DARWINOSX devices:
16:38:50 T:140735276151552 NOTICE: Device 1
16:38:50 T:140735276151552 NOTICE: m_deviceName : default
16:38:50 T:140735276151552 NOTICE: m_displayName : Default
16:38:50 T:140735276151552 NOTICE: m_displayNameExtra: Built-in Output
16:38:50 T:140735276151552 NOTICE: m_deviceType : AE_DEVTYPE_PCM
16:38:50 T:140735276151552 NOTICE: m_channels : FL,FR
16:38:50 T:140735276151552 NOTICE: m_sampleRates : 96000,48000,44100
16:38:50 T:140735276151552 NOTICE: m_dataFormats : AE_FMT_S24LE3,AE_FMT_S16LE
16:38:50 T:140735276151552 NOTICE: Device 2
16:38:50 T:140735276151552 NOTICE: m_deviceName : Built-in OutputConfusedtream0
16:38:50 T:140735276151552 NOTICE: m_displayName : Built-in Output
16:38:50 T:140735276151552 NOTICE: m_displayNameExtra: Internal Speakers
16:38:50 T:140735276151552 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
16:38:50 T:140735276151552 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
16:38:50 T:140735276151552 NOTICE: Default DVD Player: dvdplayer
16:38:50 T:140735276151552 NOTICE: Default Video Player: dvdplayer
16:38:50 T:140735276151552 NOTICE: Default Audio Player: paplayer
16:38:50 T:140735276151552 NOTICE: Disabled debug logging due to GUI setting. Level 0.
16:38:50 T:140735276151552 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
16:38:50 T:140735276151552 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
16:38:50 T:140735276151552 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:38:50 T:140735276151552 NOTICE: Loaded playercorefactory configuration
16:38:50 T:140735276151552 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:38:50 T:140735276151552 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:38:50 T:4482412544 NOTICE: Thread ActiveAE start, auto delete: false
16:38:50 T:4482949120 NOTICE: Thread AESink start, auto delete: false
16:38:50 T:4482949120 ERROR: Initialize: Unable to find device defaultConfusedtream0
16:38:50 T:4482949120 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std:Confusedtring &): Opening default device Built-in Output
16:38:50 T:140735276151552 NOTICE: Running database version Addons16
16:38:51 T:140735276151552 NOTICE: ADDONS: Using repository repository.xbmc.org
16:38:51 T:140735276151552 NOTICE: ADDONS: Using repository repository.pvr-osx64.xbmc.org
16:38:51 T:4485611520 NOTICE: Thread PeripBusCEC start, auto delete: false
16:38:51 T:140735276151552 NOTICE: Setup SDL
16:38:51 T:140735276151552 NOTICE: Display 0 has name Color LCD
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1920 x 1200 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 960 x 600 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1680 x 1050 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1600 x 1200 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1280 x 1024 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1152 x 720 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1024 x 640 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1280 x 800 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 800 x 600 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 800 x 500 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 640 x 480 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 720 x 480 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1280 x 960 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1344 x 1008 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1344 x 840 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Found possible resolution for display 0 with 1600 x 1000 @ 60.000000 Hz
16:38:51 T:140735276151552 NOTICE: Checking resolution 16
16:38:51 T:140735276151552 NOTICE: GL_VENDOR = NVIDIA Corporation
16:38:51 T:140735276151552 NOTICE: GL_RENDERER = NVIDIA GeForce 9400M OpenGL Engine
16:38:51 T:140735276151552 NOTICE: GL_VERSION = 2.1 NVIDIA-10.0.19 310.90.10.05b12
16:38:51 T:140735276151552 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
16:38:51 T:140735276151552 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
16:38:52 T:140735276151552 NOTICE: Running database version Addons16
16:38:52 T:140735276151552 NOTICE: Running database version ViewModes6
16:38:52 T:140735276151552 NOTICE: Running database version Textures13
16:38:52 T:140735276151552 NOTICE: Running database version MyMusic48
16:38:52 T:140735276151552 NOTICE: Running database version MyVideos90
16:38:52 T:140735276151552 NOTICE: Running database version TV26
16:38:52 T:140735276151552 NOTICE: Running database version Epg8
16:38:52 T:140735276151552 NOTICE: start dvd mediatype detection
16:38:52 T:4491120640 NOTICE: Thread DetectDVDMedia start, auto delete: false
16:38:52 T:140735276151552 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
16:38:52 T:140735276151552 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
16:38:52 T:140735276151552 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
16:38:52 T:140735276151552 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
16:38:52 T:4557864960 NOTICE: Thread LanguageInvoker start, auto delete: false
16:38:52 T:140735276151552 NOTICE: UpdateLibraries: Starting music library startup scan
16:38:52 T:4561203200 NOTICE: Thread MusicInfoScanner start, auto delete: false
16:38:52 T:140735276151552 NOTICE: initialize done
16:38:52 T:140735276151552 NOTICE: Running the application...
16:38:52 T:4557864960 NOTICE: -->Python Interpreter Initialized<--
16:38:52 T:4587958272 NOTICE: Thread JobWorker start, auto delete: true
16:38:53 T:140735276151552 NOTICE: starting zeroconf publishing
16:38:53 T:4588494848 NOTICE: Thread JobWorker start, auto delete: true
16:38:53 T:140735276151552 NOTICE: ES: Starting event server
16:38:53 T:4605874176 NOTICE: Thread EventServer start, auto delete: false
16:38:53 T:4605874176 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
16:38:53 T:4605874176 NOTICE: UDP: Listening on port 9777
16:38:53 T:4606410752 NOTICE: Thread TCPServer start, auto delete: false
16:38:53 T:4606947328 NOTICE: Thread MusicFileCounter start, auto delete: false
16:38:53 T:4516605952 NOTICE: Thread RSSReader start, auto delete: false
16:38:54 T:4638756864 NOTICE: Thread JobWorker start, auto delete: true
16:39:30 T:4482949120 NOTICE: Previous line repeats 1 times.
16:39:30 T:4482949120 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std:Confusedtring &): Opening default device Built-in Output
16:39:34 T:140735276151552 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
16:39:34 T:140735276151552 NOTICE: Enabled debug logging due to GUI setting. Level 2.
16:39:34 T:140735276151552 DEBUG: ------ Window Init () ------
16:39:34 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beatsteaks - Living Targets/' due to no change
16:39:34 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beavis And Butthead - The Beavis And Butt-Head Experience (1993)/' due to no change
16:39:34 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beck - 2014 - Morning Phase/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beck - 2014 - Morning Phase/Beck - Morning Phase/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bee Gees - 2010 - One Night only (Anniversary Edition)/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bee Gees - One Night Only (Anniversary Edition)(DVD)(2010)/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Behemoth - 2014 - The Satanist/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Behemoth - 2014 - The Satanist/Behemoth - The Satanist/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beirut - The Rip Tide/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bela B . Smokestack Lightnin - 2014 - Bye/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bela B . Smokestack Lightnin - 2014 - Bye/Bela B & Smokestack Lightnin - Bye/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Belle & Sebastian - Write About Love (2010)/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Belphegor - 2014 - Conjuring the Dead/' due to no change
16:39:35 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Belphegor - Blood Magick Necromance (2011)/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Ben Folds & Nick Hornby - Lonely Avenue (2010)/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Ben Harper With Charlie Musselwhite - Get Up (2013)/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Ben Howard - 2014 - I Forget where we Were/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Ben Howard - Every Kingdom/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Ben Loncle Soul - Ben Loncle Soul (2010)/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Berliner Philharmoniker - 2013 - Jahrhundert Edition/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Berlins Most Wanted - Berlins Most Wanted (Limitierte Deluxe Edition) (2010)/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bernhard Brink - 2014 - Aus dem Leben gegriffen/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bernhard Brink - 2014 - Aus dem Leben gegriffen/Bernhard Brink - Aus dem Leben gegriffen/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bernhard Brink - So oder So (2010)/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bernhard Brink - Wie weit willst Du gehn/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Berobass - Basstime (2009)/' due to no change
16:39:36 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beth Hart & Joe Bonamassa - Dont Explain/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beth Hart - Bang_ Bang_ Boom_ Boom/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beth Hart and Joe Bonamassa - 2013 - Seesaw/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beth Hart and Joe Bonamassa - 2014 - Live in Amsterdam/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beth Hart and Joe Bonamassa - 2014 - Live in Amsterdam/Beth Hart and Joe Bonamassa - Live in Amsterdam/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Betontod - 2013 - Viva Punk mit Vollgas durch die Hölle/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Betontod - Antirockstars/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Betontod - Entschuldigung fuer nichts/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beyonc'e - 2013 - BEYONC'E/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beyonce - 4 (Deluxe Edition)/' due to no change
16:39:37 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beyonce - A Gift From A Virgo (2009)/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Beyonce - I Am Yours (An Intimate Performance At Wynn Las Vegas)(2009)/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bibi und Tina - 2014 - Soundtrack/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bibi und Tina - 2014 - Soundtrack/Bibi und Tina - Soundtrack/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Biffy Clyro - 2007 - Puzzle/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Biffy Clyro - 2013 - Opposites (Deluxe Edition)/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Biffy Clyro - 2014 - Opposites (Deluxe Edition)/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Biffy Clyro - 2014 - Similarities/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Biffy Clyro - Opposites (Deluxe Version) (2013).mp3/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Biffy Clyro - Revolutions-Live At Wembley (Deluxe Edition)/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Big Time Rush - BTR/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Big Time Rush - Elevate/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bigelf - 2014 - Into the Maelstrom/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bigelf - 2014 - Into the Maelstrom/Bigelf - Into the Maelstrom/' due to no change
16:39:38 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bill Callahan - 2013 - Dream River/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bill Callahan - Apocalypse/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bill Callahan - Apocalypse/Info/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Billie Joe Armstrong & Norah Jones - 2013 - Foreverly/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Billy Idol - 2014 - Kings & Queens of the Underground/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Billy Joel - Live at Shea Stadium the Concert (2011)/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Billy Talent - Dead Silence/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Biohazard - Reborn In Defiance/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Birdy - 2013 - Fire Within/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Birdy - Birdy/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bizzy Montana - 2014 - MadU 4/' due to no change
16:39:39 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bizzy Montana - Gift/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Björk - Biophilia/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Country Communion - 2 (2011)/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Country Communion - Afterglow/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Country Communion - Black Country Communion (2010)/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Country Communion - Live over Europe/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Eyed Peas - The Beginning (Deluxe Edition) (2010)/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Label Society - 2013 - Unblackened/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Label Society - 2014 - Catacombs of the Black Vatican (Deluxe Edition)/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Label Society - 2014 - Catacombs of the Black Vatican (Deluxe Edition)/Black Label Society - Catacombs of the Black Vatican (Deluxe Edition)/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Label Society - Order of the Black (2010)/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Moth - 2014 - Condemned To Hope/' due to no change
16:39:40 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Rebel Motorcycle Club - 2013 - Specter At The Feast/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Rebel Motorcycle Club - 2013 - Specter At The Feast/2013 - Specter At The Feast/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Sabbath - 2013 - 13 (Deluxe Version)/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Sabbath - 2013 - Gathered in their Masses (Extended Edition)/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Sabbath - 2013 - Greatest Hits/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Spiders - 2013 - This Savage Land/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Star Riders - 2013 - All Hell Breaks Loose/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Stone Cherry - 2014 - Magic Mountain/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Stone Cherry - Between the Devil & the Deep Blue Sea (2011)/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Black Veil Brides - 2014 - Black Veil Brides (Deluxe Edition)/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackberry Smoke - 2014 - Leave a Scar (Live North Carolina)/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackberry Smoke - 2014 - Leave A Scar (Live North Carolina)/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackberry Smoke - 2014 - The Whippoorwill/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackberry Smoke - 2014 - The Whippoorwill/02 - Blackberry Smoke - The Whippoorwill/' due to no change
16:39:41 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackfield - 2013 - IV/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackfield - Welcome to my DNA/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackfield - Welcome to my DNA/Info/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackmail - 2013 - II/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackmail - 2013 - II/2013 - II/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackmail - Anima Now (2011)/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackmores Night - A Knight in York/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackmores Night - A Knight in York Video/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blackmores Night - Autumn Sky (2010)/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blaeck Foeoess - 40 Jahre Blaeck Foeoess (2010)/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blank Jones - Relax Edition Seven/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blank & Jones - 2014 - Relax Edition Eight/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blank & Jones - Relax Edition Six (2011)/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blessthefall - 2013 - Hollow Bodies/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 1988 - Battalions of Fear/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 1989 - Follow the Blind/' due to no change
16:39:42 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 1990 - Tales from the Twilight World/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 1992 - Somewhere Far Beyond/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 1993 - Tokyo Tales/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 1995 - Imaginations From The Other Side/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 1996 - The Forgotten Tales/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 1998 - Nightfall in Middle Earth/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 2002 - A Night At The Opera/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 2003 - Live/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 2003 - Live/CD 1/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 2003 - Live/CD 2/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 2004 - Imaginations Through The Looking Glass/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 2004 - Imaginations Through The Looking Glass/CD 1/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 2004 - Imaginations Through The Looking Glass/CD 2/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 2013 - An Extraordinary Tale/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - 2013 - Nightfall in Middle-Earth (Special Edition)/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - A Night At The Opera/' due to no change
16:39:43 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - A Twist In The Myth/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - At the Edge of Time (2010)/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - LIVE/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - Memories of a Time to Come/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blind Guardian - Nightfall In Middle Earth/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink 182 - 2005 - Greatest Hits/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink 182 - Blink 182/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink 182 - Buddha/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink 182 - Dude Ranch/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink 182 - Enema Of The State/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink 182 - Fuck you to hell/' due to no change
16:39:44 T:140735276151552 DEBUG: Keyboard: scancode: 0x00, sym: 0x0136, unicode: 0x0000, modifier: 0x0
16:39:44 T:140735276151552 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
16:39:44 T:140735276151552 DEBUG: Previous line repeats 3 times.
16:39:44 T:140735276151552 DEBUG: OnKey: 0 (0xf200) pressed, action is
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink 182 - Neighborhoods (DeLuxe Edition)/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink 182 - Take Off Your Pants n Jacket/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink 182 - The Mark Tom and Travis Show/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink182 - 2014 - Enema of the State/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink182 - 2014 - Enema of the State/29 - Blink182 - Enema of the State/' due to no change
16:39:44 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blink182 - 2014 - Greatest Hits/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blitz Kids - 2014 - The Good Youth/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blitz Kids - 2014 - The Good Youth/05 - Blitz Kids - The Good Youth/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blitzkids Mvt - 2013 - Silhouettes/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bloc Party - Four/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blokkmonsta - 2014 - Blokkhaus/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blokkmonsta - Roboblokk/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blondie - 2014 - Blondie 4(0) Ever Greatest Hits (Deluxe Redux) (Ghosts of Download)/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blood Red Shoes - 2014 - Blood Red Shoes (Deluxe Edition)/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blood Red Shoes - 2014 - Blood Red Shoes (Deluxe Edition)/Blood Red Shoes - Blood Red Shoes (Deluxe Edition)/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blood Red Shoes - In Time to Voices/' due to no change
16:39:45 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bloodhound Gang - Show us Your Hits (2010)/' due to no change
16:39:46 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blue - Roulette (2013)/' due to no change
16:39:46 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blue October - Any Man In America/' due to no change
16:39:46 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blues Pills - 2014 - Blues Pills/' due to no change
16:39:46 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blumentopf - Nieder mit der GbR (Deluxe Edition)/' due to no change
16:39:46 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blumentopf - Wir (2010)/' due to no change
16:39:47 T:140735276151552 DEBUG: ------ Window Init (Pointer.xml) ------
16:39:49 T:140735276151552 DEBUG: ProcessMouse: trying mouse action leftclick
16:39:49 T:140735276151552 DEBUG: Keyboard: scancode: 0x00, sym: 0x0136, unicode: 0x0000, modifier: 0x0
16:39:49 T:140735276151552 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
16:39:49 T:140735276151552 DEBUG: Previous line repeats 3 times.
16:39:49 T:140735276151552 DEBUG: OnKey: 0 (0xf200) pressed, action is
16:39:49 T:140735276151552 DEBUG: ------ Window Deinit (Pointer.xml) ------
16:39:49 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blur - Blur 21 The Box/' due to no change
16:39:49 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blutengel - 2013 - Monument/' due to no change
16:39:49 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blutengel - 2013 - Monument/CD 1/' due to no change
16:39:49 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blutengel - 2013 - Monument/CD 2/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blutengel - 2013 - Once in a Lifetime (Live)/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blutengel - 2014 - Black Symphonies (An Orchestral Journey)/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blutengel - 2014 - Black Symphonies (An Orchestral Journey)/Blutengel - Black Symphonies (An Orchestral Journey)/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blutengel - Nachtbringer/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Blutengel - Traenenherz (DeLuxe Edition) (2011)/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bob Dylan - 1962 - Bob Dylan/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bob Dylan - 1963 - The Freewheelin Bob Dylan/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bob Dylan - 1964 - Another Side Of Bob Dylan/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bob Dylan - 1964 - The Times They Are A Changin/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bob Dylan - 1965 - Bringing It All Back Home/' due to no change
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bob Dylan - 1965 - Highway 61 Revisited/' due to no change
16:39:50 T:140735276151552 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
16:39:50 T:140735276151552 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
16:39:50 T:140735276151552 NOTICE: Storing total System Uptime
16:39:50 T:140735276151552 NOTICE: Saving settings
16:39:50 T:140735276151552 NOTICE: stop all
16:39:50 T:4587958272 DEBUG: Thread JobWorker 4587958272 terminating (autodelete)
16:39:50 T:4588494848 DEBUG: Thread JobWorker 4588494848 terminating (autodelete)
16:39:50 T:4638756864 DEBUG: Thread JobWorker 4638756864 terminating (autodelete)
16:39:50 T:4639293440 DEBUG: Thread JobWorker 4639293440 terminating (autodelete)
16:39:50 T:140735276151552 NOTICE: stop player
16:39:50 T:140735276151552 INFO: stopping PVRManager
16:39:50 T:140735276151552 DEBUG: NetworkMessage - Signaling network services to stop
16:39:50 T:140735276151552 NOTICE: ES: Stopping event server
16:39:50 T:140735276151552 DEBUG: NetworkMessage - Waiting for network services to stop
16:39:50 T:140735276151552 NOTICE: stopping zeroconf publishing
16:39:50 T:4561203200 DEBUG: DoScan Skipping dir '/Volumes/Storage/Musik/Rips/Album - Musik/B/Bob Dylan - 1966 - Blonde On Blonde/' due to no change
16:39:50 T:4605874176 NOTICE: ES: UDP Event server stopped
16:39:50 T:4606410752 DEBUG: Thread TCPServer 4606410752 terminating
16:39:50 T:4605874176 DEBUG: Thread EventServer 4605874176 terminating
16:39:50 T:140735276151552 NOTICE: stop dvd detect media
16:39:50 T:4491120640 DEBUG: Thread DetectDVDMedia 4491120640 terminating
16:39:50 T:4485611520 DEBUG: Thread PeripBusCEC 4485611520 terminating
16:39:50 T:140735276151552 NOTICE: stop sap announcement listener
16:39:50 T:140735276151552 NOTICE: clean cached files!
16:39:50 T:140735276151552 NOTICE: unload skin
16:39:50 T:140735276151552 INFO: Unloading old skin ...
16:39:50 T:140735276151552 DEBUG: ------ Window Deinit () ------
16:39:50 T:140735276151552 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
16:39:50 T:140735276151552 DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
16:39:50 T:140735276151552 DEBUG: Cleanup - Closed bundle
16:39:50 T:140735276151552 DEBUG: ADDON: Stopping service addons.
16:39:50 T:4482412544 DEBUG: Thread ActiveAE 4482412544 terminating
16:39:50 T:4482949120 DEBUG: Thread AESink 4482949120 terminating
16:39:50 T:140735276151552 DEBUG: CCoreAudioStream::Close: Restoring original physical format for stream 0x0027. ([lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (44100Hz))
16:39:51 T:140735276151552 DEBUG: CCoreAudioStream::SetPhysicalFormat: Physical format for stream 0x0027. now active ([lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (44100Hz))
16:39:51 T:140735276151552 DEBUG: CCoreAudioStream::Close: Closed stream 0x0027.
16:39:51 T:140735276151552 NOTICE: stopped
16:39:51 T:140735276151552 NOTICE: destroy
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000f6b00 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e8800 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e8780 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e8280 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e7f00 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e7d00 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e7a80 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e7880 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e7780 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e7580 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e7200 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e7180 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e6f80 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e6c00 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6080000e6a00 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:39:51 T:140735276151552 NOTICE: unload sections
16:39:51 T:140735276151552 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:39:51 T:140735276151552 DEBUG: object 0 --> 0 instances
16:39:51 T:140735276151552 DEBUG: object 1 --> 0 instances
16:39:51 T:140735276151552 DEBUG: object 2 --> 0 instances
16:39:51 T:140735276151552 DEBUG: object 3 --> 0 instances
16:39:51 T:140735276151552 DEBUG: object 4 --> 0 instances
16:39:51 T:140735276151552 DEBUG: object 5 --> 0 instances
16:39:51 T:140735276151552 DEBUG: object 6 --> 0 instances
16:39:51 T:140735276151552 DEBUG: object 7 --> 0 instances
16:39:51 T:140735276151552 DEBUG: object 8 --> 0 instances
16:39:51 T:140735276151552 DEBUG: object 9 --> 0 instances
16:39:51 T:4606947328 DEBUG: CSettingsManager: requested setting (filelists.showhidden) was not found.
16:39:51 T:140735276151552 DEBUG: Previous line repeats 1 times.
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
16:39:51 T:140735276151552 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
16:39:51 T:140735276151552 NOTICE: application stopped...
16:39:51 T:140735276151552 DEBUG: PVRManager - destroyed
16:39:51 T:140735276151552 DEBUG: SECTION:UnloadDll(libcurl.4.dylib)
16:39:51 T:140735276151552 DEBUG: Unloading: /libcurl.4.dylib
16:39:51 T:140735276151552 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/libcpluff-x86-osx.so)
16:39:51 T:140735276151552 DEBUG: Unloading: /libcpluff-x86-osx.so
16:39:51 T:140735276151552 DEBUG: SECTION:UnloadAll(DLL: libcec.2.dylib)
16:39:51 T:140735276151552 DEBUG: Unloading: /libcec.2.dylib
MacOS detailed error message:
[quote]Process: Kodi [21054]
Path: /Applications/Kodi.app/Contents/MacOS/Kodi
Identifier: org.xbmc.kodi
Version: 14.0.rc3 (Git-20141208-bdf56d0)
Code Type: X86-64 (Native)
Parent Process: Huh [1]
Responsible: Kodi [21054]
User ID: 501
Date/Time: 2014-12-21 16:36:48.365 +0100
OS Version: Mac OS X 10.10.1 (14B25)
Report Version: 11
Anonymous UUID: 235EAC36-ABEE-6F3B-3581-9AEA7034EDEB
Sleep/Wake UUID: 5897455A-32C5-4684-84FD-7C1252FA2DD7
Time Awake Since Boot: 73000 seconds
Time Since Wake: 6100 seconds
Crashed Thread: 9 MusicFileCounter
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff921d9132 __psynch_cvwait + 10
1 org.xbmc.kodi 0x0000000100076f32 bool XbmcThreads::TightConditionVariable<bool volatile&>::wait<CCriticalSection>(CCriticalSection&, unsigned long) + 226
2 org.xbmc.kodi 0x000000010039e52d CThread::WaitForThreadExit(unsigned int) + 61
3 org.xbmc.kodi 0x000000010039f0e7 CThread::~CThread() + 103
4 org.xbmc.kodi 0x00000001002e9a5e MUSIC_INFO::CMusicInfoScanner::~CMusicInfoScanner() + 46
5 org.xbmc.kodi 0x00000001002e99bf MUSIC_INFO::CMusicInfoScanner::~CMusicInfoScanner() + 15
6 org.xbmc.kodi 0x00000001000097e8 CApplication::~CApplication() + 104
7 org.xbmc.kodi 0x000000010000960f CApplication::~CApplication() + 15
8 org.xbmc.kodi 0x000000010002e88e boost:Confusedhared_ptr<CApplication>::~shared_ptr() + 46
9 libsystem_c.dylib 0x00007fff970c18ed __cxa_finalize_ranges + 322
10 libsystem_c.dylib 0x00007fff970c1bf0 exit + 55
11 org.xbmc.kodi 0x0000000100008ddb start + 59
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff921da22e kevent64 + 10
1 libdispatch.dylib 0x00007fff945f7a6a _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff921d9946 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff8c3484a1 start_wqthread + 13
Thread 3:
Thread 4:
Thread 5:
0 libsystem_kernel.dylib 0x00007fff921d452e mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff921d369f mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff907f8b14 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff907f7fdb __CFRunLoopRun + 1371
4 com.apple.CoreFoundation 0x00007fff907f7838 CFRunLoopRunSpecific + 296
5 com.apple.CoreFoundation 0x00007fff908aded1 CFRunLoopRun + 97
6 org.xbmc.kodi 0x00000001007da582 -[HotKeyController eventTapThread] + 98
7 com.apple.Foundation 0x00007fff94e75b7a __NSThread__main__ + 1345
8 libsystem_pthread.dylib 0x00007fff8c34a2fc _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff8c34a279 _pthread_start + 176
10 libsystem_pthread.dylib 0x00007fff8c3484b1 thread_start + 13
Thread 6:
5 com.apple.AppKit 0x00007fff966957a7 _NSEventThread + 137
6 libsystem_pthread.dylib 0x00007fff8c34a2fc _pthread_body + 131
7 libsystem_pthread.dylib 0x00007fff8c34a279 _pthread_start + 176
8 libsystem_pthread.dylib 0x00007fff8c3484b1 thread_start + 13
Thread 7:: MusicInfoScanner
3 org.xbmc.kodi 0x000000010039f6d5 CThread::StopThread(bool) + 117
4 org.xbmc.kodi 0x00000001002e9fb0 MUSIC_INFO::CMusicInfoScanner:Tonguerocess() + 1088
5 org.xbmc.kodi 0x000000010039f4af CThread::Action() + 31
6 org.xbmc.kodi 0x000000010039e0b8 CThread:ConfusedtaticThread(void*) + 184
7 libsystem_pthread.dylib 0x00007fff8c34a2fc _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff8c34a279 _pthread_start + 176
9 libsystem_pthread.dylib 0x00007fff8c3484b1 thread_start + 13
Thread 8:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff921d93f6 __select + 10
1 libsystem_pthread.dylib 0x00007fff8c34a2fc _pthread_body + 131
2 libsystem_pthread.dylib 0x00007fff8c34a279 _pthread_start + 176
3 libsystem_pthread.dylib 0x00007fff8c3484b1 thread_start + 13
Thread 9 Crashed:: MusicFileCounter
0 libiconv.2.dylib 0x00007fff974ece95 iconv + 19
1 org.xbmc.kodi 0x00000001003432b2 bool CCharsetConverter::CInnerConverter:ConfusedtdConvert<std:Confusedtring, std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >(StdConversionType, std:Confusedtring const&, std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >&, bool) + 146
2 org.xbmc.kodi 0x0000000100341c7e CCharsetConverter::utf8ToW(std:Confusedtring const&, std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >&, bool, bool, bool) + 238
3 org.xbmc.kodi 0x000000010064a5b3 CGUIListItem::SetLabel(std:Confusedtring const&) + 115
4 org.xbmc.kodi 0x00000001000cd339 CFileItem::CFileItem(std:Confusedtring const&) + 377
5 org.xbmc.kodi 0x0000000100bc7ab8 XFILE::CPosixDirectory::GetDirectory(CURL const&, CFileItemList&) + 248
6 org.xbmc.kodi 0x0000000100104497 XFILE::CDirectory::GetDirectory(CURL const&, CFileItemList&, XFILE::CDirectory::CHints const&, bool) + 1015
7 org.xbmc.kodi 0x0000000100103f79 XFILE::CDirectory::GetDirectory(std:Confusedtring const&, CFileItemList&, std:Confusedtring const&, int, bool) + 105
8 org.xbmc.kodi 0x00000001002ee9ef MUSIC_INFO::CMusicInfoScanner::CountFiles(CFileItemList const&, bool) + 351
9 org.xbmc.kodi 0x00000001002eea12 MUSIC_INFO::CMusicInfoScanner::CountFiles(CFileItemList const&, bool) + 386
10 org.xbmc.kodi 0x00000001002eea12 MUSIC_INFO::CMusicInfoScanner::CountFiles(CFileItemList const&, bool) + 386
11 org.xbmc.kodi 0x00000001002eea12 MUSIC_INFO::CMusicInfoScanner::CountFiles(CFileItemList const&, bool) + 386
12 org.xbmc.kodi 0x00000001002f6489 MUSIC_INFO::CMusicInfoScanner::Run() + 233
13 org.xbmc.kodi 0x000000010039f4af CThread::Action() + 31
14 org.xbmc.kodi 0x000000010039e0b8 CThread:ConfusedtaticThread(void*) + 184
15 libsystem_pthread.dylib 0x00007fff8c34a2fc _pthread_body + 131
16 libsystem_pthread.dylib 0x00007fff8c34a279 _pthread_start + 176
17 libsystem_pthread.dylib 0x00007fff8c3484b1 thread_start + 13
Thread 10:
Thread 9 crashed with X86 Thread State (64-bit):
rax: 0xbaddc0dedeadbead rbx: 0x000000000000005c rcx: 0x0000000112cba6f8 rdx: 0x0000000112cba710
rdi: 0x0000600000307d70 rsi: 0x0000000112cba700 rbp: 0x0000000112cba740 rsp: 0x0000000112cba6a8
r8: 0x0000000112cba708 r9: 0x00000000ffffff80 r10: 0x0000000010c62695 r11: 0x000000010fb00000
r12: 0x000000010fb562f0 r13: 0x000000010fb55f00 r14: 0x00006080000ee398 r15: 0x0000000000000170
rip: 0x00007fff974ece95 rfl: 0x0000000000010202 cr2: 0x000000010b242070
Logical CPU: 1
Error Code: 0x00000000
Trap Number: 13
Binary Images:
0x100000000 - 0x102970ff7 +org.xbmc.kodi (14.0.rc3 - Git-20141208-bdf56d0) <B8578D78-3578-3B37-9B83-8798A75DE160> /Applications/Kodi.app/Contents/MacOS/Kodi
0x103f3c000 - 0x1048e4fef +libsmbclient.dylib.0 (0) <3783027F-3E5E-3741-B30F-62B9812C0300> /Applications/Kodi.app/Contents/Libraries/libsmbclient.dylib.0
0x104a12000 - 0x104a57fff +libGLEW.1.7.0.dylib (1.7) <A2A30A13-0D85-30A3-99C1-77D905ADC9E5> /Applications/Kodi.app/Contents/Libraries/libGLEW.1.7.0.dylib
0x104a83000 - 0x104af4ff7 +libSDL-1.2.0.dylib (12.4) <DC9CB8F2-C428-3646-AF1D-F35E73BBA198> /Applications/Kodi.app/Contents/Libraries/libSDL-1.2.0.dylib
0x104b07000 - 0x104b08fff com.apple.VideoDecodeAcceleration (1.1 - 8) <B624EA7A-EECA-3A30-9FE9-25C8339535BE> /System/Library/Frameworks/VideoDecodeAcceleration.framework/Versions/A/VideoDecodeAcceleration
0x104b0d000 - 0x104b11fff com.apple.agl (3.3.0 - AGL-3.3.0) <3B0D06B0-99F1-3D5F-8977-340FC462B511> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x104ffd000 - 0x104ffdff7 +cl_kernels (Huh) <DC6DA795-C765-47E5-8656-556EE372EB30> cl_kernels
0x107a5f000 - 0x107a5ffff +cl_kernels (Huh) <ACE86465-96F8-49DB-ACF1-B453633A7E09> cl_kernels
0x109d3a000 - 0x109e20fef unorm8_bgra.dylib (2.4.5) <90797750-141F-3114-ACD0-A71363968678> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x10b113000 - 0x10b117fff com.apple.audio.AppleHDAHALPlugIn (267.0 - 267.0) <EFF081E7-E74F-3C1F-81A9-14FA71560443> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x10b435000 - 0x10b43dff7 com.apple.iokit.IOUSBLib (705.4.0 - 705.4.0) <E92770C0-E737-3222-9BB8-5C3901A61AC3> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x10b8cf000 - 0x10b8dcfff libGPUSupport.dylib (11.0.7) <2DCF62FB-CC3A-35F9-A3A0-3D7251EA347F> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x10c800000 - 0x10cfa2ff7 libclh.dylib (4.0.3 - 4.0.3) <EE427831-0340-376C-95E5-CBA07D723D67> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/libclh.dylib
0x123440000000 - 0x12344088ffff com.apple.GeForceTeslaGLDriver (10.0.19 - 10.0.0) <7BB3C5E4-9A1F-37B3-8ABC-450350086642> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/GeForceTeslaGLDriver
0x7fff6686f000 - 0x7fff668a5837 dyld (353.2.1) <4696A982-1500-34EC-9777-1EF7A03E2659> /usr/lib/dyld
0x7fff8c22a000 - 0x7fff8c22afff com.apple.Carbon (154 - 157) <6E3AEB9D-7643-36BE-A7E5-D08886649257> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8c22b000 - 0x7fff8c22bfff com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8c22c000 - 0x7fff8c25cfff libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
0x7fff8c25d000 - 0x7fff8c298fff com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff8c299000 - 0x7fff8c2b3ff7 com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8c2b4000 - 0x7fff8c2b4fff com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8c347000 - 0x7fff8c350fff libsystem_pthread.dylib (105.1.4) <26B1897F-0CD3-30F3-B55A-37CB45062D73> /usr/lib/system/libsystem_pthread.dylib
0x7fff8c351000 - 0x7fff8c368ff7 libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff8c38d000 - 0x7fff8c4f8ff7 com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5C6DBEB4-F2EA-3262-B9FC-AFB89404C1DA> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff8c4f9000 - 0x7fff8c761ffb com.apple.security (7.0 - 57031.1.35) <96141D1F-614E-32C4-8AC2-F47481F23F43> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8c772000 - 0x7fff8c7e6fff com.apple.ApplicationServices.ATS (360 - 375) <62828B40-231D-3F81-8067-1903143DCB6B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8c7e7000 - 0x7fff8c80ffff libsystem_info.dylib (459) <B85A85D5-8530-3A93-B0C3-4DEC41F79478> /usr/lib/system/libsystem_info.dylib
0x7fff8c810000 - 0x7fff8c825ff7 com.apple.AppContainer (4.0 - 238) <9481F305-359A-33E6-93F1-89A25FA14E00> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A
please get rid of posting logs on the forum and use pastebin.com
Same problem .. how to fix? HuhConfused
well its a bug for sure - but i have a workaround for you until someone can look into it. Is waiting until scanning is finished before quitting kodi an option?
I've been having the same issue. Forcing the scans to stop or waiting till it finishes allows Kodi to quit without freezing, but it still quits with a "Kodi unexpectedly quit" dialog. I'm just dealing with it for now, but hopefully this gets resolved in an update.
then post the crashreport from this dialog please
