Full Version: Annoing popup "DVBlink PVR Client"
Hi all,
I'm running Kodi with DVBLink PVR Addon and I would like to completely disable annoing DVBLink popup with texts like:
- "DVBlink PVR Client"
- "Found 0 Timers", or "Found 0 records"
It popup very often and to be honest, I don't want it to see it at all Wink
Pop-up keeps appearing like once in five minutes even if the PVR client is inactive. Any ideas how to stop it?
Maybe is my question stupid, but of course, I tried to find any answer here, than on DVBLink forum and finally through Google - nothing.
Thank you in advance,
regards,
Martin
Problem SOLVED!
In the DVBLink XBMC PVR Addon settings there is a special check box - "show information messages". Uncheck it and it should be fine.
