Full Version: AEON MQ5 Frozen screen
Hello guys,
I downloaded the Aeon MQ5 on my new android 4.4 MyGica box, when asked if this is what I wanted to change to I said yes. It went to the front page and all it shows is AEON MQ 5 on my tv and seems like its frozen. Anyone have any idea what could be wrong?
I have the same problem. I am using Gotham XBMC install on my Android Minix X8-H (KitKat 4.4.2). Freezes at splashscreen. I tried to create a log, but since MQ5 freezes, I cannot upload the log file properly. So, I turned on debugging and restarted XBMC. XBMC loaded to Ace, my normal skin, but then, by using settings/appearance, I changed the skin to MQ5. After freezing at the splash screen again, I went to my xbmc.log location and uploaded it to dropbox.
https://www.dropbox.com/s/2ozwwwujtlrp4km/xbmc.log?dl=0
Somebody please tell me if I am submitting this log correctly.
just let it go ...and build a snowman.
