Full Version: LiveTV disappears
All,
I'm having this problem where I can get everything to work properly with Kodi and MythTV. After a day or so, "Live TV" will disappear off the menu and I can't get it to reconnect. My setup is a HD HomeRun box, a mythtv backend running on another system, and then Kodi connecting to the mythtv backend box.
I'm attaching my debug logs. In the debug log, I tried to disable and re-enable the pvr addon. I also tried to 'search for channels' in the settings. Any help is appreciated.
http://pastebin.com/V7C0iMHs
It doesn't sound like your problem, but just make sure that you have the LiveTV option enabled. When I turned it off, I lost the menu item for TV to watch recordings. Seems like a bug...
Scott
Thanks for the response. I think I finally somehow got it working. After a few days of it disappearing and me enabling/disabling the addon and the livetv settings, I think I got it working fine now. Strange, but it works.
