Full Version: openpli vu+ duo kodi, importing epg from clients kodi and open webif interface
Pages: 1 2
openpli, vu+ duo, kodi, importing epg from clients kodi and open webif interface is very very slow. when using xbmc 13.2 nothing problem but when i am using kodi 14 this problem was happen. kodi 14 eating vu+ duo cpu. i am waiting for one day importing epg clients for kodi. but not yet finished.
kodi hacking vu+ duo openpli system like a dos attack. this problem may be happen open pli program because importing epg from kodi not freezing open pli.
please send me a solution thank you.
Mem: 112464K used, 19396K free, 0K shrd, 116K buff, 48520K cached
CPU: 50% usr 0% sys 0% nic 48% idle 0% io 0% irq 1% sirq
Load average: 1.02 1.02 1.05 2/86 1920
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
605 601 root R 84428 64% 50% /usr/bin/enigma2
1665 1662 root R 3192 2% 0% top
1565 1 root S 21744 16% 0% /usr/bin/CCcam
507 1 root S 3968 3% 0% nmbd -D
1661 556 root S 2956 2% 0% /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
509 1 root S 6924 5% 0% smbd -D
526 509 root S 6924 5% 0% smbd -D
584 1 avahi S 3612 3% 0% avahi-daemon: running [vuduo.local]
585 584 avahi S 3612 3% 0% avahi-daemon: chroot helper
569 1 root S 3244 2% 0% /usr/sbin/inetd
1662 1661 root S 3192 2% 0% -sh
548 1 messageb S 2984 2% 0% /usr/bin/dbus-daemon --system
573 1 root S 2872 2% 0% /sbin/syslogd -n -O /var/log/messages
576 1 root S 2872 2% 0% /sbin/klogd -n
601 1 root S 2872 2% 0% {enigma2.sh} /bin/sh /usr/bin/enigma2.sh
532 1 root S 2872 2% 0% udhcpc -b -H vuduo -p /var/run/udhcpc.eth0.pid -i eth0
560 1 rpc S 2788 2% 0% /usr/sbin/rpcbind
556 1 root S 2700 2% 0% /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
565 1 rpcuser S 2284 2% 0% /usr/sbin/rpc.statd
1 0 root S 1944 1% 0% init [3]
114 2 root SW 0 0% 0% [sched_low]
115 2 root SW 0 0% 0% [sched_high]
10 2 root SW 0 0% 0% [rcu_sched]
49 2 root SW 0 0% 0% [ubi_bgt0d]
24 2 root SW 0 0% 0% [kworker/1:1]
3 2 root SW 0 0% 0% [ksoftirqd/0]
1911 2 root SW 0 0% 0% [kworker/0:2]
50 2 root SW 0 0% 0% [ubifs_bgt0_0]
610 2 root SW 0 0% 0% [ca04]
1914 2 root SW 0 0% 0% [kworker/0:1]
11 2 root SW 0 0% 0% [migration/1]
116 2 root SW 0 0% 0% [sched_idle]
6 2 root SW 0 0% 0% [kworker/u:0]
611 2 root SW 0 0% 0% [ci_kthread]
2 0 root SW 0 0% 0% [kthreadd]
8 2 root SW 0 0% 0% [migration/0]
16 2 root SW 0 0% 0% [kdevtmpfs]
43 2 root SW 0 0% 0% [scsi_eh_0]
44 2 root SW 0 0% 0% [scsi_eh_1]
153 2 root SW 0 0% 0% [lcd]
It looks like there is no development anny more for this plug-in.
I would have expected that EPG importing would be faster with KODI - do you have any debug logs?
I'm using the the latest OpenELEC and the initial EPG import for 130 seconds is < 2 seconds.
I have same issue with openwebif, however if i remove and install the old webif all works fine. seems there is something with openwebif which make the enigma box work much much hared to provide epg data..
Can you elaborate a littlebit further what you mean with old & new webif?
I'm still using a very old VTI image (End of support in July 2014 - guess I need to update it at some time...Smile)
Regards,
Joerg
(2015-05-27, 11:12)jdembski Wrote: [ -> ]Can you elaborate a littlebit further what you mean with old & new webif?
Regards,
Joerg
new webif means openwebif https://github.com/E2OpenPlugins/e2openplugin-OpenWebif
old webif means the original dm webif http://wiki.openpli.org/e2Webif
In vu+ enigma client 1.9.11 no problem. very good running but newer versions problem.
(2015-04-24, 03:02)gendo Wrote: [ -> ]I have same issue with openwebif, however if i remove and install the old webif all works fine. seems there is something with openwebif which make the enigma box work much much hared to provide epg data..
mate how do you install the old one??
i also have really slow epg, if i even try to open the PVR menu Kodi will freeze if the EPG i still loading. This issue started when upgraded to 15.x. I have not changed anything in my dreambox so the issues is in kodi for me i would guess. i haven't clocked it but i would guess somewhere around 4-5 minutes to load epg on boot up.
A handy tip but its a techy one, if your handy with webservers configure one with a (proxy)cache, once cached epg loads under 2 seconds (500 channels 40mb data) gb local lan and 5 seconds via 4g, or get TwistedWeb to act as a cache onboard-inthebox. Or get enigma2 imagebuilders to make this as a plugin.
Also experiencing this issue on Kodi 16 alpha 4. I am unable to add a proxy cache to enigma2's web server, so the plugin is unusable in this state, as it causes a continuous CPU load on the enigma2 box of 90%+.
Yes i have made some tests, I thought it was my image that was the cause I my case but now I have tried 4 different images for my DM800HD clone box and its the same independent of image. Will see if I can find the old webif and test.
As it is now my epg import takes someware around 35 minutes...I can't restart kodi anymore or put the computer to sleep mode...damn!!
Pages: 1 2
