2015-01-11, 10:29
I've molded the Aeon Nox Shednox fork skin to a near perfect version for myself.
Find the current version of this mod here. Then download the updated 1080I folder here. Replace the 1080i folder in the main download with this one for all the latest updates.
I use mainly Showcase, Landscape, Shift and Episode views for Movies and TV Shows. I've also done some work with the Tri-Panel for a specific reason.
All MPAA rating, Audio, Aspect Ratio and Resolution flags are all my custom.This included Dolby Atmos and Auro 3D Audio. Many studios flags have been added and/or modded as well most source flags and a number of others.
To begin, Showcase view for Movies.
Removed votes in brackets from the IMDB rating. Also better spaced all the floor icons. Aspect Ratio flag is based on adding the AR to the file name and path naming convention.
Added an icon for IMDB Top 250 films.
Added Oscar statue icon for Best Picture films, based on file naming convention similar to the AR or format.
Also reduced the title width to fit the re-spaced and added icons, and to make it look better than the super wide width it was.
Movies Landscape View
- All the same changes, additions and deletes as the Showcase view.
- Extra Info is movie year, runtime and rating, not tagline
Further mods at the links below.
Movie Info Screen Changes.
Video Player Info Screen
TV Show Mods
Best Picture and IMDB Top 250 sub-menu mods.
In order to use naming conventions for proper flags and icons you MUST use the following naming conventions:
Dolby Atmos - filename and path must include "Atmos"
Best Picture Oscar - filename and path must include "BestPicture"
Correct Film Aspect Ratio - filename and path must include the AR for that specific video. AR's included are as follows,
1.20:1 = 120
1.33:1 = 133
1.37:1 = 137
1.37:1 = 142
1.66:1 = 166
1.75:1 = 175
1.78:1 = 178
1.85:1 = 185
2.02:1 = 202
2.22:1 = 222
2.29:1 = 229
2.31:1 = 231
2.35:1 = 235
2.40:1 = 240
2.44:1 = 244
2.55:1 = 255
2.76:1 = 276
For TV shows in a different pixel aspect than the video aspect use the following,
4:3 Standard TV AR = TV43
16:9 High Defenition TV AR = TV169
TV Show Mods
1.20:1 = 120
1.33:1 = 133
1.37:1 = 137
1.37:1 = 142
1.66:1 = 166
1.75:1 = 175
1.78:1 = 178
1.85:1 = 185
2.02:1 = 202
2.22:1 = 222
2.29:1 = 229
2.31:1 = 231
2.35:1 = 235
2.40:1 = 240
2.44:1 = 244
2.55:1 = 255
2.76:1 = 276
