Hello Community
I'm searching for a list of all vnsiserver command line parameters
Running version 1.2.0 latest from GIT, with VDR 2.1.6, Ubuntu 14.0.4.1
Did a search already but couldn't find a complete list
I'm sure there is one out there :-)
would be great if anyone know's
Martin
Hello FernetMenta
Thanks for the Info provided
-t n, --timeout=n stream data timeout in seconds (default: 10)\n
-d , --device act as the primary device\n
-s n, --test=n TS stream test file to simulate as channel\n"
So I figure:
-d has to be set if VDR is runnig headless, and VNSI is the main / only way to consume LiveTV
-t does what exactly ?
does parameter -d combined with -t make sense at all ??
besides that...
My Problem concering sporadic VDR crashes is solved
Tested on all my clients over the last two weeks
http://forum.kodi.tv/showthread.php?tid=210534&page=3
Thanks again for the fix
https://github.com/FernetMenta/vdr-plugi...b58f457c95
Regards
Martin
parameter -t is some heritage and not important. if there is no signal, vnsi sends some update to the addon after this time
I implemented -d after some changes in vdr which prevent tuning to a channel in idle state if primary device has no decoder. If you want to use femon to adjust your dish, this parameter may be useful.
