(2015-01-14, 19:32)channy310 Wrote: [ -> ]looking to change the background image on the menus.. its just one image for all, i would like to change it to something plain. where exactly do i change this? see picture attached to see exactly what i mean just incase i failed to explain it properly
thanks in advance
http://s1067.photobucket.com/user/channy...sort=3&o=0
^^^ image
@ channy310 samu-rai is correct.
CHANGING BACKGROUND IN KODI 18.3 LEIA
For the benefit of new users, I will try to explain in simple detail.
First of all I should say that each way of doing this will
differ slightly, depending on the skin you are using.
In this example I am using the folowing:
KODI 18.3 Leia
SKIN Aeon MQ8 v2.9.0 for Leia by Marcos Qui
Using Windows Explorer
In this example the folder path takes me to the "backgrounds" folder that is inside of a folder
with the same name as the skin I have active. (aeonmq8)
Folder Path
"C:\Users\xxxxx\AppData\Roaming\Kodi\addons\skin.aeonmq8\backgrounds"
With Windows Explorer navigate to this "backgrounds" folder.
Inside of the "backgrounds" folder are 2 other folders, "composition" and "extras".
Ignore these 2, we only need to change things in the "backgrounds" folder.
So, if you look in the "backgrounds" folder, you will see some of the jpg pictures
have simple basic names, like, "pictures.jpg" or "movies.jpg" or "tvshows.jpg" .
These jpg files correspond to the background image used for that Main Menu
item / page. So, simply replace these pictures with the picture you want for that item / page,
using exactly the same name again. Caution, you may want to rename and
copy & paste the original out, before you start each one, to avoid overwritng the original picture.
If you want all of the Main Menu items / pages to have the same background picture, then simply
replace each of the jpg files (using the same simple names) with the same picture you want.
Torc
