Full Version: Suggestion/idea - separate the SYNC & SEARCH functions in the UI
I don't know if this has been suggested before but I just want to suggest mange the developer could consider separating these two functions. At the moment if you are browsing music in the app, and you pull down to show the SEARCH box, if you pull it too far it will attempt to sync your media. Which is cool, but not what you wanted.
Perhaps it would be good to move the sync option to another place in the app? I agree that pulling down from the top of a menu is a natural method for refreshing, but how often do people do a manual sync using the app?
I think it would be better elsewhere. Anyway just a suggestion, and sorry if its already been pointed out.
sincerely I don't see the issue you are describing :O It's very hard start the sync while you want to show only the search box from my POV...
I agree, if you're careful about it, it's not a problem. It's only a niggle really.
