I'm trying to display the outdoor temperature in Kodi home screen.
So far that works, but I want it to auto refresh every 5 minutes or lets say every minute to follow the clock.
Here's how I have done it.
outdoor.xml (This file is being updated every 5 minutes.)
PHP Code:
<?xml version="1.0" encoding="UTF-8"?>
<includes>
<variable name="outdoor">
<value>1,0</value>
</variable>
</includes>
Home.xml
PHP Code:
<control type="label">
<description>outdoor</description>
<posx>20r</posx>
<posy>60</posy>
<width>200</width>
<height>15</height>
<align>right</align>
<aligny>center</aligny>
<font>font10</font>
<textcolor>white</textcolor>
<shadowcolor>black</shadowcolor>
<label>Outdoor: $VAR[outdoor] °C</label>
<include>Window_OpenClose_Animation</include>
<animation effect="slide" start="0,0" end="-40,0" time="100" condition="Window.IsVisible(Mutebug)">conditional</animation>
</control>
The problem is that the only way to refresh the $VAR is to reboot
Any help would be very much appreciated!
/Patric
well, it won't work like that.
Kodi only reads all xml files once, at startup.
instead, you'd need to create a python script
and have the script periodically update a window property.
script part:
xbmcgui.Window(10000).setProperty('outdoor', '1,0')
skin part:
<label>Outdoor: $INFO[Window(Home).Property(outdoor)] °C</label>
(2015-01-21, 02:17)ronie Wrote: [ -> ]well, it won't work like that.
script part:
skin part:
Thanks a lot!
I will try to figure how to do that
Ok, so I managed to do it my dirty way. I don't have any education in programming so I tend to find my own ways of achieving my goal
This is my temperature python script that is being generated every 5 minutes by wget'ing a php script at my temp monitoring server.
PHP Code:
import xbmc, xbmcgui
HOME = xbmcgui.Window(10000)
xbmcgui.Window(10000).setProperty('Inne', '22,6')
xbmcgui.Window(10000).setProperty('Ute', '1,3')
My Home.xml
PHP Code:
<description>Inne</description>
<posx>20r</posx>
<posy>60</posy>
<width>200</width>
<height>15</height>
<font>font12</font>
<label>Inne: $INFO[Window(Home).Property(Inne)] °C</label>
</control>
<description>Ute</description>
<posx>20r</posx>
<posy>75</posy>
<width>200</width>
<height>15</height>
<font>font12</font>
<label>Ute: $INFO[Window(Home).Property(Ute)] °C</label>
</control>
Now to find a way to execute the python script I linked it to the yellow button at my remote.
The script runs and the values are updated as well.... But how can I run this script every 5 minutes?
I was hoping a cronjob would do it but obviously that doesn't work since only kodi can handle this because of the "imports"...
EDIT: After a lot of reading I found a method that allowed me to use cronjob for the update task.
PHP Code:
*/5 * * * * kodi-send --action="XBMC.RunScript(/storage/scripts/temp.py)" >/dev/null 2>&1
Only "problem" now is that the screen saver inactivates when the command is sent
If anyone has another (better) method that I should use instead, please let me know.
Put something like the following in startup.xml or home.xml
<onload>Alarmclock(RefreshTemp,RunScript(/storage/scripts/temp.py),05:00,silent,loop)</onload>
That would work although I'd just wrap the thing into a service addon and make it less hacky. It would be pretty simple, just update that property, sleep for 5 minutes, and repeat until xbmc is shutdown.
(2015-01-21, 20:24)MassIV Wrote: [ -> ]Put something like the following in startup.xml or home.xml
Thanks a lot!
That worked really well.
(2015-01-21, 21:00)robweber Wrote: [ -> ]That would work although I'd just wrap the thing into a service addon and make it less hacky. It would be pretty simple, just update that property, sleep for 5 minutes, and repeat until xbmc is shutdown.
Oh, I found your thread now when you mentioned "service addon". I didn't know there was an addon like that util now...
I figured the only way to do this was by hacking.
I will for sure look into to your addon.
(2015-01-21, 22:01)ronie Wrote: [ -> ]Service_addons (wiki)
It looks like I have to do something like that because my logs are filling up with this:
PHP Code:
10:17:03 261.442749 T:2667086912 NOTICE: -->Python Interpreter Initialized<--
10:17:03 261.443298 T:2667086912 WARNING: CPythonInvoker(2): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
