2015-01-24, 03:49
2015-01-24, 03:59
Rip them from your DVDs or blurays onto your server or nas and play them via the network.
2015-01-24, 04:04
(2015-01-24, 03:59)nickr Wrote: [ -> ]Rip them from your DVDs or blurays onto your server or nas and play them via the network.
Sorry I'm new to all this. How do you move them onto your server?
2015-01-24, 11:48
This is such a simple-looking question that I suspect we need to start at the beginning:
1. what sort of media do you get your movies from?
2. do you have a PC which can network with the Pi, and what OS is it running?
2015-01-24, 17:01
(2015-01-24, 11:48)dandnsmith Wrote: [ -> ]This is such a simple-looking question that I suspect we need to start at the beginning:
I have a windows desktop and I'd like to get my movies from either ITunes or DVDs either way works
2015-01-25, 00:00
(2015-01-24, 17:01)Slapshot135 Wrote: [ -> ](2015-01-24, 11:48)dandnsmith Wrote: [ -> ]This is such a simple-looking question that I suspect we need to start at the beginning:
You can forget iTunes AFAIK that simply won't work. If you rip a DVD and store the movies in a folder and then share that folder you'll be able to add that folder as a source in KODI.
2015-01-25, 00:24
(2015-01-25, 00:00)speedwell68 Wrote: [ -> ](2015-01-24, 17:01)Slapshot135 Wrote: [ -> ](2015-01-24, 11:48)dandnsmith Wrote: [ -> ]This is such a simple-looking question that I suspect we need to start at the beginning:
I'm not sure how you guys do this but I tried moving the dvd into a flash drive and it partially worked- I got video but not audio
2015-01-25, 10:21
(2015-01-25, 00:24)Slapshot135 Wrote: [ -> ]I'm not sure how you guys do this but I tried moving the dvd into a flash drive and it partially worked- I got video but not audio
You'll need some sort of DVD ripping software. Personally I use the excellent DVD Catalyst, but there are other options around like Handbrake or MakeMKV, depending on what format you want to end up in and what other features you may want. Some are free, some aren't but are quite cheap usually and should work with most DVDs.
If you want BluRay then you need a bit more effort, but I can't help there as I don't have any so have never done it.
2015-01-27, 02:58
(2015-01-25, 00:24)Slapshot135 Wrote: [ -> ]Actually figured it out- the speakers I had the Pi connected to werent turned on(I feel like an idiot now)(2015-01-25, 00:00)speedwell68 Wrote: [ -> ](2015-01-24, 17:01)Slapshot135 Wrote: [ -> ]I have a windows desktop and I'd like to get my movies from either ITunes or DVDs either way works
