Hi Guys ,
Just moved across from Gotham to Kodi have a few minor niggles with the setup.... Could some one help with box sets I can't get the scrip info to work in the bottom right
All help would be appreciated
Hi Jasn,
Thanks for the reply
I've downloaded and installed but I have the same issue
do I need to use a older version to get the script to work?
Does the script skin info service appear activated in Add-ons? It should be in the Enabled -> Program Add-ons section.
You also may just need to reboot your system. I recall me having to fiddle with it a bit too.
Hi Cutsickass,
Just got back in will double check shortly
Cheers Jasn,
Will do that as well
(2015-01-24, 20:05)CutSickAss Wrote: [ -> ]Does the script skin info service appear activated in Add-ons? It should be in the Enabled -> Program Add-ons section.
Hi Guys,
Just checked my enabled program addons and its running
Also have done a hard reset and update library but no joy
Having a blond moment .........
All sorted
. Thanks for all your help guys
