Hi there - i have been running gotham for a while and till airplay was broken generally due to ios issues - it worked.
I have updatet to kodi and my mobile devices won't find kodi no more.
Generally - i have two vlan's inplace one for the mobile devices , one for the kodi - devices and a gateway in between where i run avahi-daemon.
One of the devices is still on xbmc Gotha,-Version and is discovered well - the new ones with kodi are not - what can i do to track the issue or to investigate further?
Question ?
Have you played around with Kodi settings
Kodi > System > Settings > Services > Airplay > iOS 8 compatibility mode
Hard to provide help when you neglect to tell us what iOS version these mobiles use ?
log enabled, grep on airplay gives:
root@amenophis:/home/user/.kodi/temp# grep -i airplay kodi.log
05:46:08 T:140618106640320 INFO: AIRPLAY: Cleaning up photoassetcache
05:46:08 T:140618106640320 INFO: AIRPLAY Server: Successfully initialized
05:46:08 T:140616281351936 DEBUG: CZeroconfAvahi::doPublishService identifier: servers.airplay type: _airplay._tcp name:Kodi2 port:36667
05:46:08 T:140616289744640 NOTICE: Thread AirPlayServer start, auto delete: false
05:46:08 T:140616281351936 DEBUG: CZeroconfAvahi::addService() named: Kodi2 type: _airplay._tcp port:36667
17:25:47 T:140618106640320 INFO: AIRPLAY: Cleaning up photoassetcache
17:25:47 T:140616289744640 DEBUG: Thread AirPlayServer 140616289744640 terminating
17:25:47 T:140618106640320 DEBUG: CZeroconfAvahi::doRemoveService named: servers.airplay
17:25:48 T:140618106640320 INFO: AIRPLAY: Cleaning up photoassetcache
17:25:48 T:140618106640320 INFO: AIRPLAY Server: Successfully initialized
17:25:48 T:140617355093760 DEBUG: CZeroconfAvahi::doPublishService identifier: servers.airplay type: _airplay._tcp name:Kodi2 port:36667
17:25:48 T:140617355093760 DEBUG: CZeroconfAvahi::addService() named: Kodi2 type: _airplay._tcp port:36667
17:25:48 T:140616289744640 NOTICE: Thread AirPlayServer start, auto delete: false
switching iOs' compatibility-mode does not change anything
Discovering the kodi-devices from the mobile device for xbmc-remote works fine for all the devices - and discovering a printer via airprint also works well over the vlan's
i also checked an xbmc on the same machine like kodi which discovers fine. Log for xbmc says:
user@amenophis:~/.xbmc/temp$ grep -i airplay xbmc.log
19:16:08 T:139665882101696 INFO: AIRPLAY Server: Successfully initialized
19:16:08 T:139665032591104 DEBUG: CZeroconfAvahi::doPublishService identifier: servers.airplay type: _airplay._tcp name:XBMC2 port:36667
19:16:08 T:139664654456576 NOTICE: Thread AirPlayServer start, auto delete: false
19:16:08 T:139665032591104 DEBUG: CZeroconfAvahi::addService() named: XBMC2 type: _airplay._tcp port:36667
19:17:04 T:139664654456576 DEBUG: Thread AirPlayServer 139664654456576 terminating
19:17:04 T:139665882101696 DEBUG: CZeroconfAvahi::doRemoveService named: servers.airplay
19:17:13 T:139665882101696 INFO: AIRPLAY Server: Successfully initialized
19:17:13 T:139665049376512 DEBUG: CZeroconfAvahi::doPublishService identifier: servers.airplay type: _airplay._tcp name:XBMC2 port:36667
19:17:13 T:139664669267712 NOTICE: Thread AirPlayServer start, auto delete: false
19:17:13 T:139665049376512 DEBUG: CZeroconfAvahi::addService() named: XBMC2 type: _airplay._tcp port:36667
19:17:31 T:139665882101696 DEBUG: CZeroconfAvahi::doRemoveService named: servers.airplay
19:17:32 T:139664669267712 DEBUG: Thread AirPlayServer 139664669267712 terminating
i don't see that much difference in the logs
1. please grep for raop and airtunes aswell
2. Just prove the full log via pastebin.com and link it here...
