2015-01-28, 21:13
After Upgrading to kodi i'm experiencing this problem:
when i play tv episodes or movies, if I use the exit button on the atv2 remote, kodi does not mark the entry as watched (if i exit just before the ending titles for example)
and it neither set the resuming point.
If, instead i press the pause button and then the exit button, then it works correctly for both resuming and watched state.
It is not a real big problem but i've always pressed the esc button before put the atv to sleep and it worked correctly
Now, every night when i go back to the "on progress" episodes, it always play the episode i've already watched the day before and of course at the end I always forget to press the pause button before exiting :o))).
Any suggestion?
Thank you
Any suggestion?
Thank you
