Full Version: System freezes on favorites widget
I use ace with xbmc 13.2 beta 3
I've noticed that whenever I leave the application on the favorites menu for a few hours , weather it's with the widget or without, the whole application freezes and I need to reboot...
Can someone give me a hint of what's going on in there?
If it is possible post your log file here. Does the problem only occur with Ace and the favorite menu? Which Ace version are you currently using?
Hi
Sorry for the late reply...
I now upgraded to kodi 14.2 with your ace master skin.
Still I have the same problem on the favorites widget.
I'll try to post the log files soon...
Here are the logs:
This is the log from the night of the freeze : http://xbmclogs.com/ptlyfp3bj
(as you can see it terminates at about 01:47 am)
This is the log from after the reset of the device (just in case) : http://xbmclogs.com/ph42crk7u
Hope you can solve my problem.
