Yes. Probably later today, although there's no immediate rush...
Milhouse for president !!1
(2015-02-02, 10:15)Milhouse Wrote: [ -> ]although there's no immediate rush...
Oh, I Beg to Differ
Is the current OpenELEC build likely to run on the new Pi, just using one core, or won't it be working at all?
(2015-02-02, 10:48)dantist Wrote: [ -> ] (2015-02-02, 10:15)Milhouse Wrote: [ -> ]although there's no immediate rush...
Oh, I Beg to Differ
no, it needs at least OpenELEC-5.0.1 with a own build (which will be released later today (if all goes well) on
http://www.openelec.tv)
Ordered one first thing in the morning, can't wait to test performance.
Raspberry Pi B2 sold out in Holland...
is just 2 hours
(2015-02-02, 10:48)dantist Wrote: [ -> ]Is the current OpenELEC build likely to run on the new Pi, just using one core, or won't it be working at all?
Unfortunately that won't work as you'll need a new ARMv7 kernel but I'm pretty confident there will be official OpenELEC RPi2 builds publicly available before the first Pi2's are dropping through letter boxes!
Upgrading a Pi1 installation to Pi2 should be fairly trivial - basically just replace the kernel.img and SYSTEM files in the FAT partition. The firmware is the same.
(2015-02-02, 10:59)Milhouse Wrote: [ -> ]Upgrading a Pi1 installation to Pi2 should be fairly trivial - basically just replace the kernel.img and SYSTEM files in the FAT partition. The firmware is the same.
That sounds nice! Just ordered mine
drools....
nice work.
2 x things that currently suck...
1) -took delivery of 2 x model B+ this morning
2) - aust distributor has NA listed as stock quantity for PI 2 :-((
cant wait.
uuuhhh just figured out, that the RS Components Supplier is just around the corner 10km away!
It's like christmas and birthday happening on the same day.
I just ordered 6 in absolute panic. I thought if i don't get them now it will take them months until they can supply enough for the high demand.
It is such a great piece of hardware for only a few bucks.
Hopefully it will be capable of hevc 720p -or even 1080p- main profile software decoding?
(2015-02-02, 10:58)Warez Wrote: [ -> ]Raspberry Pi B2 sold out in Holland... is just 2 hours
Last time I checked kiwi-electronics had some in stock, but their website is down ATM. I ordered one from Pimoroni instead.
