Full Version: help with custom backgrounds for each main menu item
Hi guys,
Jeroen made it clear that he will not be adding option for different background based on main menu item.
Since I am an enthusiast photographer (or whish to think I am Tongue ) i would like to have that option in refocus.
For last week I have been trying to make sense of how skin works, but I am not a coder unfortunately.
So far I was able to add "Select background" option in main manu costumistaion options and it is browsable.
Added this to script-shortcust.xml
    <!--set background-->
    <control type="button" id="310">
        <width>492</width>
        <include>dialog_ControlCommons</include>
        <label>$ADDON[script.skinshortcuts 32045]</label>
        <label2>$INFO[Container(211).ListItem.Property(Background)]</label2>
    </control>
And added this to overrides.xml
<background label="Vidoes">home\videos\</background>
    <background label="Music">home\music\</background>
    <background label="DVD">home\dvd\</background>
    <background label="Movies">home\movies\</background>
    <background label="TVShows">home\tvshows\</background>
    <background label="Pictures">home\pictures\</background>
    <background label="Weather">home\weather\</background>
    <background label="Settings">home\settings\</background>
    <background label="Shutdown">home\shutdown\</background>
    <background label="Favourites">home\favourites\</background>
    <background label="Addons">home\addons\</background>
    <backgrounddefault label="Vidoes" group="mainmenu">home\videos\</backgrounddefault>
    <backgrounddefault label="Music" group="mainmenu">home\music\</backgrounddefault>
    <backgrounddefault label="DVD" group="mainmenu">home\dvd\</backgrounddefault>
    <backgrounddefault label="Movies" group="mainmenu">home\movies\</backgrounddefault>
    <backgrounddefault label="TVShows" group="mainmenu">home\tvshows\</backgrounddefault>
    <backgrounddefault label="Pictures" group="mainmenu">home\pictures\</backgrounddefault>
    <backgrounddefault label="Weather" group="mainmenu">home\weather\</backgrounddefault>
    <backgrounddefault label="Settings" group="mainmenu">home\settings\</backgrounddefault>
    <backgrounddefault label="Shutdown" group="mainmenu">home\shutdown\</backgrounddefault>
    <backgrounddefault label="Favourites" group="mainmenu">home\favourites\</backgrounddefault>
    <backgrounddefault label="Addons" group="mainmenu">home\addons\</backgrounddefault>
But nothing i happening Tongue
If someone could point me in the right direction that would be grate.
I would not mind if paths to folders are hardcoded just to get it running.
So, you've got the button that opens the window to select backgrounds, you've got the paths set up, but you still need an actual image control that actually displays the chosen background(s) Smile
Assuming you want to use a folder of images and not a single picture per item that would be something like:
PHP Code:
<control type="multiimage">
    <include>
screen_Dimensions</include>
timeperimage>10000</timeperimage>
fadetime>300</fadetime>
randomize>true</randomize>
imagepath background="true">$INFO[Container(9000).ListItem.Property(Background)]</imagepath>
control
This will go in home.xml. Assuming you don't care about keeping the other background options available you'll want to delete (or better comment out) this include:
PHP Code:
<include>home_Background</include>
And put the image control from above after that line.
The container number 9000 refers to the home menu's ID number. Adjust things like timerperimage and fadetime to your liking. You can also use:
PHP Code:
<fadetime>fadetime_Fanart</fadetime
To use the skin's global default or adjust that global value in includes.xml:
PHP Code:
<constant name="fadetime_Fanart">300</constant
timeperimage and fadetime are in milliseconds.
Hope that helps.
Jeroen thank you Smile
Spot on, works like a charm.
I made a mistake in my first post, will correct it when I have some more time.
Thank you again for your help, and thanks for Refocus - it is imho one of the best skins out there Smile
Thanks, good luck modding Smile
I dont get it... Dont get it to work
Sorry for late replay, do not know how i missed it.
If you still need it I could put the skin on one drive so you can download it.
Regards
Hi guys I am a total noob and I have made my own firestick build I would like to put my own backgrounds on but what them two posts say is a load of gobble-de-gook to me Sad is there a total noob way of doing it? thanks
(2015-04-29, 14:20)Burke Wrote: [ -> ]Sorry for late replay, do not know how i missed it.
Regards
dont suppose you could put this up again mate? cheers
